Parts Interchange
Old Jul 6, 2015 | 09:32 AM
WBCC's Avatar
Parts Interchange
Is there a list here somewhere for parts interchange? Have a '69 S that needs various sheet metal (nose) and other parts and was wondering models and years that will work. Thanks!
Old Jul 6, 2015 | 09:51 AM
allyolds68's Avatar
68 & 69 are very similar but have different grills, hoods, deck lids and bumpers. The fenders sometimes interchange as long as they have the 69 bolt pattern
Old Jul 6, 2015 | 11:19 AM
WBCC's Avatar
Am I correct that '69 and '70 interchange? How about two-door and four-door noses...same?
Old Jul 6, 2015 | 12:07 PM
Not even close. Google Images is your friend. The 1970 HOOD can be made to fit a 69, but that's all that will interchange, and even that isn't a bolt-on. Body lines are different, grilles are different, bumpers are different, core supports are different. Hollanders Interchange Manual is the "list" you want.
Yes. Through the 1972 model year, all A-body Oldsmobiles used the same sheetmetal from the firewall foreward within a given model year. Grilles and trim may differ among models (ie, 442 or Supreme grilles vs. a base Cutlass) and there were typically different hood styles (some flat, some raised) within a given year, but they will bolt in place of one another.
Keep in mind that in the 1960s, most sheet metal and trim was one-year-only. Even the 1968-69 front fenders, though externally the same, are not identical. Hood hinges and the corresponding mounting points are different from 68 to 69, for example.
Old Jul 6, 2015 | 12:19 PM
WBCC's Avatar
So I really should be looking for true '69 parts...ok. the double hump hood...really want one. I'm seeing images of those on S's, Supremes, some flat, some not......what's the deal?
Old Jul 6, 2015 | 12:22 PM
WBCC's Avatar
Old Jul 6, 2015 | 12:23 PM
WBCC's Avatar
Nevermind...found my answer in an older thread.
WBCC's Avatar
'70 hoods need to be modified...anyone done this? what's required? Hinge locations?Thanks.
Old Jul 6, 2015 | 12:26 PM
For everyone else's benefit, the double hump hoods came on all 1969 442s, Cutlass 2drs, convertibles, and W-31s (including F-85s). All other 69 Olds A-bodies (lesser F-85s, Supremes, wagons, and more-doors) got the flat hood.
Old Jul 6, 2015 | 12:27 PM
Actually, it's the latch. You need to modify the 1969 core support to incorporate the 1970 latch.
Old Jul 6, 2015 | 01:32 PM
RROLDSX's Avatar
Or as I like to refer to them as power bulges 😜
jon1957
Brakes/Hydraulic Systems
Apr 11, 2012 11:47 AM
dharlett
Feb 7, 2008 11:36 AM
Mister
Jan 2, 2008 08:26 PM
ijasond
Jun 5, 2007 11:21 AM
ndiver63
Aug 27, 2006 02:01 PM
