Horn contact for 1970 Olds Cutlass Supreme
Old Jun 29, 2015 | 12:32 PM
mjrocketride350's Avatar
Having trouble locating a new horn contact kit for my 1970 Olds Cutlass Supreme. Part of mine is missing so the horn does not work unless I pull the horn pad off and stick a screw driver in the contact hole. Where can I find the new kit for it?
Old Jun 29, 2015 | 12:42 PM
toymobile's Avatar
How does it attach to the back of the horn button???
Old Jun 29, 2015 | 12:45 PM
It's part of the turn signal switch. There is a hole on the steering wheel that the pin sticks through and when the button is pressed it makes contact with the pin.
Old Jun 29, 2015 | 12:53 PM
toymobile's Avatar
If I am thinking of the right part I used a spring out of ball point pen, Good luck.
Old Jun 29, 2015 | 12:55 PM
I have the spring. The problem is the pin is not sticking through the hole enough to make contact with the button. I'm missing the bushing that goes on the pin.
Old Jun 29, 2015 | 06:05 PM
If this is the contact for a four spoke sport wheel, every Camaro repro parts vendors sells them. Typical price is $5 or so. Just type Camaro horn contact kit into Google.
Old Jun 29, 2015 | 10:02 PM
Interesting that a similar thing was just posted yesterday:
https://classicoldsmobile.com/forums...n-problem.html
You can get it at your local NAPA store:
http://www.napaonline.com/Catalog/Ca...822_0374189805
Old Jun 30, 2015 | 03:59 AM
It's not a sport wheel. The horn button goes across the whole wheel.
therobski
Oct 25, 2014 12:16 PM
hinz57
Jun 27, 2009 09:37 PM
Olds luvr
Feb 4, 2009 11:59 AM
silverriff
Mar 2, 2008 02:14 PM
