Oil recommended
Oil recommended
Hi guys. I need oil I changed it w/15w 40w Classic Car Motor Oil, I was going to buy Valvoline Vr 1 but they don't have it in 15w 40w What weight would you guy recommend I'm in Lexington SC ,they have 10/30 weight This engine is screwed up but I need some till the builder decides what they are going to do.
Thanks all
Steve
Thanks all
Steve
Thanks I took it out today to reset my atomic setting ran fine no noise,but It smoked when I started it ,I just got off the phone with the builder He said it could be the PCV,it's getting oil on my EFI ,I shook it they was noise but that's definelty not the noise when it taps, He said as long as I got oil in it It should be alright to drive,I was thinking of taking the PCV out and but breathers on it that's how I had it before,I'm am getting fed up with this BS
Take Care
Steve
Take Care
Steve
I'd try another mechanical oil pressure gauge to be sure. If it is still low then there are issues. You should have 50-60+ when cold and at least 25 hot idle with a fresh engine. The old rule of thumb is a 10# gain per 1000 rpm.
Morning I swap the guage same readings,I was looking for a PCV I found one but would not fit it valve cover way to small I gotta come up with a groumet and I'm going to add the crank case from the other cover to the air cleaner,
Steve
Steve
Well I took it out ran alright a little noise starting ,went down the street punched it Oil coming out of both pipes,I go home take all the crap off PCV etc I put my 3 vented caps on ,called the engine builder he gave me a bunch of crap,The guy who put it in is going to call him I guess they don't want to pay for taking engine out ,I had oil problems since new ,we will see I about had it w/this car this is the 2 times rebuilt,I can't keep doing it,I should of put a 350 Rocket in it,
So I wait till my guy talks to the engine guy.
Steve
Steve
Indy_68_S
Drivetrain/Differentials
March 5th, 2012 06:04 AM
labrats804
July 19th, 2007 07:16 AM
