Peak Molding: Was it an option on All 70-72 Cutlass/442?
Old April 26th, 2015, 10:58 AM
1971 442 conv
Texas442's Avatar
B85 Molding: Was it an option on All 70-72 Cutlass/442?
I have a door shell from a rust free 72 Cutlass Supreme. I noticed it has the peak molding on it. Was this molding an option on all 70-72 Cutlass? Could you get it ordered on a 442?
Texas442 is offline
Old April 26th, 2015, 11:09 AM
Wrong terminology. That's B85 molding. Answer is no, not all cars were produced with that option. Most had the thin bead molding.
FYI Peak Molding refers to the thin stainless that run full length of the body along the top fenders, doors, and quarter panels on 68/69 models.
Allan R is offline
Old April 26th, 2015, 03:00 PM
Yes, it was optionally available on the 442. My 1970 W-30 has the B85 molding.
joe_padavano is online now
Old April 26th, 2015, 04:13 PM
Actually, to be complete in the answer, it was an option on ALL the Cutlass Coupes (which doesn't include the CS vert). It wasn't an exclusive to 442 option. The B85 door molding fits the entire A body coupe lineup. Where it differed was the quarter window reveal. The B85 quarter glass moldings that are hardest to find are the ones for the 3687 and 3677 models.
BTW, thanks for correcting the title of the thread Joe.
Allan R is offline
Old April 26th, 2015, 05:19 PM
I wasn't the one who corrected the thread title.
Old April 26th, 2015, 05:26 PM
Boiler_81's Avatar
My 1970 W30 also has the B85 molding. It must have been a low take rate option. I haven't seen very many with the option.
Boiler_81 is offline
Old April 26th, 2015, 05:57 PM
Rocketbrian's Avatar
Just for further info, the B85 moulding was standard equipment on the 70-72 Cutlass Supreme hardtop if the option C08, vinyl top was ordered.
Rocketbrian is offline
Old April 26th, 2015, 07:15 PM
1971 442 conv
Texas442's Avatar
Thanks for all the valuable information. I've only seen this molding on a couple of cars here. I guess most people take them off after a repaint.
Texas442 is offline
Old April 26th, 2015, 07:49 PM
spf1410's Avatar
My car has B85 also. I seem to remember the term "Belt Reveal Molding" - does anyone know if this refers to B85?
spf1410 is offline
Old April 26th, 2015, 08:05 PM
Yes.
Allan R is offline
Old April 27th, 2015, 01:08 PM
DJS70cutlass's Avatar
My 70 "S" has these moldings as well. Were they standard on the "S" by chance? ......seems like most that I see have them.
DJS70cutlass is offline
Old April 27th, 2015, 01:32 PM
They were a rare option on both the "S" and the 442 hardtops. As Allan stated, the door mouldings are the same for the Supreme and the "S" models. It is the moulding for the quarter panel that is very hard to find as it was specific to the fastback roofline. It took me quite a while to locate them for my 71 442 that I am restoring. I then sent them to have the anodizing removed and then rebuffed. They make quite a difference in the look of the car.
Old April 27th, 2015, 01:39 PM
Diego's Avatar
From the numbers I have from the GM Heritage Center (through June 1970, which means July production is unaccounted for), 12.8% of 4-4-2 coupes built in 1970 had B85.
Diego is offline
Old April 27th, 2015, 02:27 PM
According to that information, of the 16,397 442 coupes built in 1970 2098 had B85 moldings. That however doesn't address the number of f85/Cutlass/Cutlass S that may have been ordered with B85. In 1970 this total (excluding 442's) was 111,578. So if the percentages are about the same, that would make the approxamite grand total for 1970 alone:
02,098----442 coupes
14,282----Cutlass/f85/Cutlass S
16,380----Total
Notes and presumed:
1) This is ONLY for the fastback coupes; not verts. Includes post and Holiday coupes.
2) Doesn't take into account post June production, so numbers could be slightly higher.
3) The 71 and 72 production is not factored either. There were undoubtedly a fair number of coupes in those respective years with B85 molding.
Net belief: There should still be a fair number of surviving cars that may have the B85 moldings.
I searched for 2 years before I found the rear quarter B85 moldings for my 72 Cutlass S. They need a specific fastening method to install which is slightly different than the conventional bead molding. As Brian notes, these are anodized pieces, not stainless so they don't just 'buff out' unless you're extemely lucky. Another option to anodizing is powder coating. Depends on your budget. I think Brian's budget is bigger than mine as his curved fastback moldings were NOS when he bought them IIRC.
Allan R is offline
Old April 27th, 2015, 02:34 PM
Diego's Avatar
The percentages are not the same, which is why it's not a good idea to make an approximate estimation.
Diego is offline
Old April 27th, 2015, 03:04 PM
Do you have percentages for B85 3387 and 3377 models from 1970-72 that were not 442s? After all, the B85 is exactly the same part numbers for the related models in those years.
Allan R is offline
Old April 27th, 2015, 03:06 PM
Diego's Avatar
Yeah, I can post them later.
Diego is offline
Old April 27th, 2015, 03:14 PM
Would you have stats for the 71 442, model 4487 ?
Old April 27th, 2015, 03:19 PM
Diego's Avatar
Yeah, and it'll be for the full model year too - no missing July!
Diego is offline
Old April 27th, 2015, 03:30 PM
That will be great. Not to bother you too much, but do you have production stats for all options? I would love to know how many 71 442s came with the bench seat, A52, as mine did. It was a credit option. My apologies for for going off topic a bit. Thanks.
Old April 27th, 2015, 05:56 PM
Diego's Avatar
Here's 1970 THROUGH JUNE 1970 (so for you folks who are ADD, this is most of production but not total:
B85
3577,3587: 3.3%
3677,3687: 7.9%
4257: 1.1%
1971 - this is TOTAL production through July:
B85
3500: 4.4%
3600: 7.6%
4200: 0.8%
4400: 15.1% (approx 950)
A52:
4400: 15.5% (approx 973)
1972 THROUGH JUNE 1972 (so for you folks who are ADD, this is most of production but not total:
B85
3600: 5.6%
4200: 0.4%
Diego is offline
Old April 27th, 2015, 06:50 PM
Thanks very much for the information. Interesting to know.
tru-blue 442
May 25th, 2014 07:16 AM
bd519@optonline.net
May 16th, 2014 02:46 PM
firefighter5174
December 6th, 2013 12:22 PM
mikealandrum
June 4th, 2013 06:16 AM
Topless72
June 5th, 2009 07:18 AM
Quick Reply: Peak Molding: Was it an option on All 70-72 Cutlass/442?
