List of options
List of options
My 1969 442 was built in Oshawa Canada and has a large list of
options,A01,A31,A39,A46,A82,A85,A91,B93,C08,C60,D3 3,D55,JL2M,40,N34
N40,N81,PO2,UF1,U35,U69,U75,U80,W39,W84,Y60,AND,Z4 9 Why are most of these codes on the body tag up to M40 then they ran out of room but my 1968 w30 and my 1969 convertible don't show these option codes anyone have any idea
In looking at a '67 CA built 442 body tag, I just added a long list of RPO's to a tab in my PN database
so far I only have '67, and a few '68-9 RPO's on the list. For the most part, one imagines, the same RPO code meant more or less the same thing across several years, but new ones had to be developed for example when disk brakes became available.
These are the options for 1973-77 Cutlasses but some are the same. I've highlighted some that may be similar.
A01 - Tinted Windows
A31 - Windows - Power Side
A39 -
A46 -Not sure but A48 is seat belt delete
A82
A85
A91 - A90 is power trunk
B93 - Door Edge Moldings
C08 - C09 is vinyl top
C60 - Air Conditioning
D33 - Aux. Floor Mats - Rear
D55 - Front Compartment Console
JL2 - Front Disc Brakes - Power
M40 - Transmission - Automatic TH-400
N34 - Steering Wheel - Custom Sport
N40
N81
P02 -P01 is Wheel Discs 14"
UF1
U35 - Electric Clock
U69 - Radio - AM-FM Mono
U75 - Antenna, Power, Front Fender
U80 - Rear Speaker
W39
W84
Y60 - Lamp and Convenience Group
Z49 - Mandatory Base Canadian Equipment
Contact http://www.gm.ca/gm/english/shopping/parts/vintage and they will sell you a break down of options, dealership where car was purchased, numbers imported to Canada and a host of other information. I think it's $100 and it's information specifically about your car. Good luck.
I already have GM of Canada documentation for my w30 and my 69 442 hard top it gave me a list of what my car's came with, just didn't no why GM in the USA didn't put any options on the body tag like CANADA'S GM plant did
They had that piece of paper to add options with
When they were done with it, it got tossed.
They foolishly believed they were just building transportation machines, not special things about which folks would later argue the exact shade of silvery gray used on the wheels, the percent gloss of the semi-flat black used underside, the amount of overspray to be found on the mufflers, etc.
