Where to buy Power Seat cables??
So are you needing the complete cables and housings, or just the cables that fit inside? The power bucket seat brackets of this vintage are worth a premium, so finding the housings may be difficult. If that's what you need I've heard of, but never tried using the more common power bench cables from full sized cars. Then loop the excess length and tie off with a zip tie.
The internal cables may work, but the ones on ebay have the newer connections in the housings.
Then you mention the actuator that runs back and forth. I may have one on a Toro bench seat bracket that I've already pulled some parts off of. I'll have to dig it out and compare it with yours to see if it will interchange.
John
John
Thanks guys.
John, yes, already have the housings.
But would need good shape square cables that fit inside.
For the actuator, maybe found one, but waiting for the seller info to conclude the deal!
Christophe2m6
Feb 7, 2015 09:49 AM
