Non functional gas guage
Old Feb 5, 2015 | 04:54 PM
orence1's Avatar
I have a newly asquired 1972 Olds Toronodo with a non-functioning gas guage. I am hopeful that it is the float/sending unit in the tank. Can anybody direct me to a source for a replacement. If it ends up being the guage, anybody have a working replacement? Many thanks for any help/advice.
Old Feb 5, 2015 | 05:24 PM
1970cs's Avatar
Lansing built
Determine whether it's the sender, wiring or gauge first!
Check connections at both ends first, if no issues there, then remove wire from sending unit and turn key to on position and ground the wire, the gauge should swing opposite direction prior to grounding, this proves that the wiring and gauge is working. Then it's drop the fuel tank time if the sender is bad! There are places that can repair them like Bob's speedometer.
Pat
Old Feb 5, 2015 | 06:52 PM
orence1's Avatar
Thanks for the tip.
Old Feb 7, 2015 | 03:59 PM
Sampson's Avatar
Can you be more specific on non functioning? Does the gauge stay on full? Or does it go to empty? I have a new in the box sending unit I will give you a good deal on if it turns out to be the sender.
Old Feb 8, 2015 | 05:10 PM
orence1's Avatar
The gas gauge is stuck beyond full. I am hopeful that it is the sending unit. I had the same problem in my 72 Chevy truck. First time was the sending unit, second time was the gauge. I am going to do some testing this week and if it is the sending unit I would be interested in yours. PM me with the price you are asking for the unit.
Old Feb 11, 2015 | 04:31 PM
m455sx's Avatar
Olds Nut
My Sx U21 (gas gauge with factory gauges)gas gauge has been stuck on full for 12 years, I have had the car since 2001 and the gauge was working for a year or 2. After 2 years or less it would work until i filled the tank completely up. then it stayed on full. i purchased new sender and fuel lines and installed them, to no avail it still doesn't work. I have pulled the gauge out to make sure all connection are tight as well as the circuit board is intact. The sending unit is working correctly as per OHM meter but gauge doesn't work??? Anybody have any ides?
Old Feb 11, 2015 | 08:50 PM
Troubleshooting procedure posted above:
Pat
Old Feb 12, 2015 | 05:47 AM
Grounding the sender wire with the key on will drive the needle to "E". Disconnecting the wire and leaving the circuit open will drive the needle to "F".
Old Feb 12, 2015 | 07:42 AM
RandyS's Avatar
And if the needle doesn't move at all, you probably have a wire fault between the rear and the dash. You can test the gauge itself with a 9 volt battery to verify it moves.
Old Feb 12, 2015 | 05:09 PM
Disconnecting the wire on mine causes the needle to go past F to the HOT light.
442garage
Vista Cruiser & Wagons
Feb 16, 2013 08:31 PM
OldsManNJ
Nov 14, 2012 03:53 PM
69442C
Oct 30, 2012 08:05 AM
Finn5033
Apr 10, 2012 09:23 AM
cbogartjr
17
Aug 7, 2008 05:13 AM
