Day 1 model year 1970 Olds - any model
Old Jan 29, 2015 | 01:42 PM
a1970442's Avatar
Hi all,
Just out of curiosity, who has a car built on day one of the 1970 model year?
I believe my vert was but I was wondering what other cars rolled off the line
before mine. Mine has a 08A date code and heard from a member on ROP
that about 1,600, give or take, cars were built a day. That would put mine
a little after half way into the cars built that day if that number is accurate.
There were only 2 days in the 1st week of August of 1969, Fri and Sat,
so I know it was one of those two days depending on the number of cars
built a day. Mine was built in the Lansing plant.
Thanks for any info provided!
Old Jan 29, 2015 | 03:07 PM
Did GM build cars over the weekend?
Old Jan 29, 2015 | 03:35 PM
Octania's Avatar
from what I understand, GM had no problem requiring 6 or even 7 days a week.
Old Jan 29, 2015 | 03:51 PM
1970cs's Avatar
Lansing built
I am sure that some pilot cars were run before real production cranked up. But yes, August 1st week is a very early car! What plant did it come from? I would assume that being in Chi town it came from Lansing? But this many years it could have came from any plant.
Kurt (Wmachine) my have records on when exactly production began.
Pat
Old Jan 29, 2015 | 04:32 PM
sammy's Avatar
Sammy70 455 Supreme
My Supreme is a Freemont build..
BF 00449
O8E, build sheet schedule date is Aug 29 1969
....100891 body sequence..
Do not know if this helps, but the car was a fairly early build...
Ted
Old Jan 29, 2015 | 05:05 PM
Diego's Avatar
Originally Posted by a1970442
Hi all,
before mine.
What's the sequence number of your car, aka the last several digits in your car's VIN?
Old Jan 29, 2015 | 05:58 PM
66-3X2 442's Avatar
I don't believe that will help determine the build date. I don't have the 69 & up build start dates for the various plants but I do have 65-68. It appears that F-85 builds followed the Toro lines a week or more in those years. Beings the vin sequence includes all models and the F-85 following the Toro models,I doubt that will help. It appears by my records that in 66 the Toro started production on 8/16 followed by the F-85 & big cars on 9/13. In 67 Toro started on 8/9 followed by F-85 on 8/25 & big cars on 8/29. In 68 Toro started on 8/7 followed big cars on 8/17 & the F-85 on 8/18.
Old Jan 29, 2015 | 06:02 PM
Diego's Avatar
No, but a car with a -0053 sequence number is much more interesting than one with a -6459 sequence, with the former implying it's during the first day.
Old Jan 29, 2015 | 06:16 PM
Paladin31's Avatar
My 70 was born on 8-18-69, body# 8087, vin four eight seven four, card shows 63rd car in sequence. 08B date
Hope this is of some use
Old Jan 29, 2015 | 06:25 PM
oldolds88's Avatar
sometimes, after changeover, when the line started back up,it could take 2 days to get the first cars off the line due to stopages. usually it was paint dept. now keep in mind ididnt start there till 76, and it was the same thing for the 28 yrs i was there. even when there wasnt change in the body,there were changes in technology and procedures.there were time we wouldnt get a car for hours,then get 4 or 5 then another gap then more cars.
Old Jan 29, 2015 | 07:21 PM
66-3X2 442's Avatar
That's my point,if other models were being built a week or more,it can't have a low vin sequence #. The body # on the cowl tag might be another story.
Old Jan 29, 2015 | 07:33 PM
Bear also in mind that you had to fill the lines, too. The plants I work for, if you want to count a body panel from coil steel to a fender rolling out the door on a car, you're looking at 2 to 3 shifts in Stamping and stores, 2 shifts in Weld, a shift in paint, maybe one in the paint buffers, depending on when Assembly wants it, and two in Assembly.
Old Jan 30, 2015 | 06:44 AM
a1970442's Avatar
Pat
Pat,
I forgot to mention that important piece of info. Sorry. It was built in the Lansing plant.
The other thing is that I don't have the door decal, so I don't know what that date is.
Diego,
It is M101048.
Old Jan 30, 2015 | 06:57 AM
That's not correct. For the 1969 model year, Toro VIN sequence numbers started with 500001. Other models started with 100001. In later years this was broken up even further, with full size cars getting a different start number also.
Old Jan 30, 2015 | 07:13 AM
66-3X2 442's Avatar
I stand corrected. I didn't realize that the Toro used a different start # for the vin. When did they change to different start #'s for the different models?
Old Jan 30, 2015 | 09:09 AM
Diego's Avatar
It is M101048.
Well, that's the 1048th vehicle off the line of whatever they built there.
Old Jan 30, 2015 | 09:26 AM
Olds built all models in Lansing. Since we know a Toro would have been a 5000x number, this is 1048th of A, B, and C-body cars.
Gitso
Jan 5, 2015 05:14 AM
DjBillT
Apr 9, 2012 04:21 PM
Oldsmobile Iron
Jan 10, 2011 08:16 PM
Warhead
Oct 8, 2010 02:05 PM
rocketraider
Mar 21, 2009 12:22 PM
