A/C and Edelbrock heads
Old Jan 23, 2015 | 04:14 AM
zekecut70's Avatar
Is there any issues with running the stock A/c brackets with the Edelbrock heads? The vehicle is 1970 Cutlass with the A/C mounted on the pass. side. Also, I'm using the Edelbrock Performer intake if that makes a difference. Thanks.
Old Jan 24, 2015 | 04:06 AM
DLaz70OLDS98's Avatar
You may have an issue with fitment of the bracket over the valve cover.
Old Jan 26, 2015 | 10:37 AM
dc2x4drvr's Avatar
You'll have to use stock height valve covers to clear the a/c bracket. Now, FWIW, I've read that the aluminum A6 can be run without that bracket, since I have the aluminum compressor I might remove the bracket just to do a little engine compartment clean up.
Old Jan 26, 2015 | 06:29 PM
wls559's Avatar
I ran into issues w/ the 455 E-Brock Performer Manifold and stock rear AC bracket. The pre threaded hole did not matchup by about 1/4 inch. I augered out the bracket hole a little and filled the factory hole on the manifold. Then drilled and tapped a new one in. Fits great now.
Bill
crank shaft
Jan 29, 2014 03:20 PM
StickW31
Nov 14, 2013 03:07 PM
f-85
Mar 29, 2013 07:39 AM
Creativeindy
Sep 11, 2012 05:38 AM
