assembly lube on rocker assembly?
Old September 1st, 2014, 05:32 AM
stratoblues's Avatar
Just had a valve job on my 57 super88, rocker assemblies had to be replaced, purchased nors assemblies from Northwestern auto supply in gd rapids had to disassemble and clean up some surface rust (not a problem) wondering if on reassembly I should use some assembly lube to make sure they are well lubed at start up?
thanks in advance
gerry
stratoblues is offline
Old September 1st, 2014, 06:01 AM
I would.
MDchanic is offline
Old September 1st, 2014, 06:52 AM
If you are going to prime the oil system prior to start, assembly lube won't be necessary.
oldcutlass is online now
boese1978
February 14th, 2014 10:56 AM
jensenracing77
April 25th, 2012 05:09 PM
ziff396
Drivetrain/Differentials
September 9th, 2008 05:19 PM
coreyshu
Brakes/Hydraulic Systems
September 4th, 2008 09:38 AM
Lady72nRob71
March 12th, 2008 05:31 AM
Quick Reply: assembly lube on rocker assembly?
