2GC Carb Rebuild
Old Aug 30, 2014 | 08:35 PM
starfire's Avatar
2GC Carb Rebuild
Rebuilt the carb on my '78 Starfire. Lots of documentation on how to do it, except: idle mixture screw adjustment. All I can find is they say don't make an adjustment to these unless rebuilding the carb. I tried backing them out 2 turns each (swag), then setting all of my adjustments. Is that the right thing to do? Is there a technique for setting the idle mixture screws?
Thanks,
Old Aug 30, 2014 | 08:52 PM
Octania's Avatar
Adjust for best idle and vacuum reading. Back in 1/8 turn for economy.
Old Aug 30, 2014 | 09:05 PM
johnnyjaws's Avatar
screw the mixtures screws in all the way not hard to break the tips off back out 2 1/2 tuens go from there 1/4 turns at a time till you get best idle out of it I alaways go another 1/4 turn out
Old Aug 31, 2014 | 06:03 AM
twintracks's Avatar
I was taught to turn them in until you start to loose RPMs, and then back them out 1/2 a turn. May not be right, but it seems to work well on most.
Old Aug 31, 2014 | 06:27 AM
If the carb in your '78 is original, it's not a 2GC, it' a 2MC or a 2ME.
Old Aug 31, 2014 | 04:51 PM
starfire's Avatar
Eric, the carb on my car is original. It is a 2GC. That's what came on the Chevy 305's in the H-Special bodies in 1978.
Old Aug 31, 2014 | 06:09 PM
Okay then. I had not been aware that GM used that carb past about 1975, but I've been wrong before.
Old Aug 31, 2014 | 06:31 PM
starfire's Avatar
You'll have to get in line way behind me if we're lining up in order of how many times we've been wrong, but yes, the 2GC was used, I think all the way up through 1980 (but I'm not positive on that), in the V-8 H-bodies.
Old Sep 2, 2014 | 09:40 PM
johnnyjaws's Avatar
Some carbs have block off caps u have to remove
Old Sep 3, 2014 | 04:17 AM
starfire's Avatar
No caps on mine. I can use a flat head screwdriver or a 6 point socket to adjust mine.
I find it very odd that the adjustment information is not to be found in any of the factory manuals. In the three replies I got on this thread, they are all slightly different on how to do it. Seems almost like witchcraft instead of science
Old Sep 3, 2014 | 04:45 AM
techg8's Avatar
I use a vacuum gage hooked to manifold vacuum
With a stock carburetor, I start 1.5 to 2 turns out from fully seated.
Adjust the screws for maximum vacuum reading achievable at idle rpm. Adjust one mix screw, see the result then match the other one. Reset idle rpm if needed.
counterclockwise turns richen. Clockwise turns lean the mix.
If when you richen the mix the rpms go up, the engine likes the additional fuel. If the rpms do not rise, youv ereached saturation point where more fuel will only hurt. If you go too far rich, you'll get a wavy uneven idle.
I look for the point where if I go rich a half turn on a single screw, there seems to be no effect on rpm, but also where if I go half a turn lean, the rpms will drop a little. I view this as the "tipping point", where youre getting max vacuum
As mentioned above, some people like to go a fraction of a turn leaner from there, I believe primarily to avoid fouling plugs at idle.
Old Sep 3, 2014 | 05:42 AM
Ken above gives a good description of the standard way of adjusting mixture, and this is what I would probably do.
HOWEVER...
The reason why your '78 manual doesn't describe this procedure is because the carburetor is supposed to be properly set and sealed at the factory, and so never need further adjustment.
In order to adjust it properly, you technically need an emissions sniffer to check the levels of the appropriate gasses. There will be a procedure for this somewhere, either in one of the GM submanuals that they published in these years, or in an aftermarket manual, such as a Motor manual.
I wouldn't lose sleep over it.
Old Sep 3, 2014 | 03:36 PM
starfire's Avatar
Ken,
Thanks for the step by step. Can I assume this is done with the engine fully warm?
starfire
Jan 5, 2014 08:32 PM
Skitch72
Oct 17, 2013 06:46 AM
77GCSX
Nov 22, 2011 09:16 AM
blackcherry
Apr 18, 2011 08:25 PM
tribunicus
Nov 5, 2009 06:37 PM
