1972 cutlass convertible top diagram
Does anyone have a link to the convertible chassis diagram. I cannot find a diagram needed to order parts. I am specifically looking for the "adjustment flat plate which is located on the convertible rail on left rear rear side" I do not know the actual name but my convertible top guy said this plate will help adjust the top. At some point before I purchased the car someone either removed the plate and put in a bolt. It goes without saying that the lack of a plate is causing other issues like the metal arm sagging on driver side. I was told that this adjustment item is near the piston. Appreciate any feedback as it looks like Year One and OPGI and others do not have them. If I had a diagram I could be more productive in identifying the parts needed. Sorry for this long winded posting.
72 convert. top parts
Hi, I was able to find a diagram of the part needed. Please see hand diagram and one from 72 Chassis Book. The part on lower left had side is two serrated plates with a bolt going through it. Without the part the rail sags on driver side. Does anyone have these parts? or have suggestions where to find it. I checked Hemmings and could not find it.
