Nut, bolt and hardware ID 72 Cutlass
Old Jul 22, 2014 | 04:40 PM
FlyBoy72's Avatar
I have an assembly manual for my 72 Cutlass covert and I am putting in a T44 interior hood latch release. the manual says I need 2 9419663 screws for the interior mounting!???
The car is very original down to the orig carb, rad, upper ball joints, console, Am/FM Stereo radio, etc, so I'm trying to keep it as such.
Does anyone know where I might get part number info on such things as attaching hardware? Any companies out there that caters to this?
Old Jul 22, 2014 | 04:59 PM
oldspackrat's Avatar
If I remember correctly they are very similar to if not the same as the screws that hold the AC lap vent assy. at the bottom of the dash or any of the quarter inch headed black screws that hold the dash together?
Old Jul 22, 2014 | 07:15 PM
FlyBoy72's Avatar
Ahh, that's a good idea. Use the Assembly manual to identify another identical screw that I already have, such as the A/C vent screw. I have the same situation for the screws that hold the clamps under the hood.
Thanks oldspackrat
Old Jul 22, 2014 | 08:36 PM
marxjunk's Avatar
if you search my screen name, i sold one a year or two ago and the bolts where with it..i posted pics..but dont have access right now to the pics on my computer
Old Jul 23, 2014 | 07:26 AM
At the risk of offending you, I must point out that adding equipment that was not installed from the factory means that the car is no longer "original". Certainly you are free to do whatever you want to the car, but don't kid yourself that the car is still "original" after adding the hood release. There are far too many "original" cars out there that now have every option in the sales catalog, whether they were built that way or not. Saying that you want to keep the car "factory correct" would be a better way to phrase it.
Again, I'm not criticizing what you are trying to do, just trying to clarify terminology.
Old Jul 23, 2014 | 12:34 PM
mrolds69's Avatar
They are #8 x 18 x 1/2", you can get them from AMK.
Old Jul 23, 2014 | 01:37 PM
ROCKET VAPOR's Avatar
Lance
FWIW, AMK has these GM hardware parts numbers listed in their catalog, so you can use this as a good "general reference".
https://www.amkproducts.com/
Old Jul 23, 2014 | 01:39 PM
FlyBoy72's Avatar
Unfortunately, I've already had an oil cap and dipstick stolen from the car when some one went and popped the hood and helped themselves. And I didn't want to do the chain down thing I've done in the past. So at this point it's the best option.
Appreciate your comment, but I will not be turning it into a 442 wanabe
Old Jul 23, 2014 | 01:42 PM
FlyBoy72's Avatar
Thanks, That's the info I'm looking for,
Old Jul 23, 2014 | 01:43 PM
FlyBoy72's Avatar
Will be checking them out. Thanks.
bob p
Jun 4, 2015 01:53 PM
rodan
Apr 27, 2014 05:01 PM
Hairy Olds
Mar 4, 2014 04:45 PM
CUT-N-UP
Sep 7, 2013 08:24 PM
oldzy
Jan 30, 2012 11:03 PM
