Exhaust Condensation
Old Feb 17, 2014 | 04:08 PM
miko442's Avatar
When starting my olds 442 with 455ci., there is a lot of condensation coming out rear tips.
It looks a little rusty as well.
It actually is quite messy, and I was wondering if anyone had a fix.
Maybe the Florida climate??
Thanks,
Mike
Old Feb 17, 2014 | 04:30 PM
johnnyjaws's Avatar
take it for a drive to dryout the mufflers and pipes . worst thing is to start a car and not let it dry out the exhaust that's why the exhausts rot out
Old Feb 17, 2014 | 04:31 PM
miko442's Avatar
Any idea on how long? Just up to temp or more,
Thanks, by the way.
Old Feb 17, 2014 | 08:07 PM
Keegan's Avatar
Mine does this as well, sometimes. If I drive it just down the street to work or fire it up and not let it run for very long, it will spit out a good amount of condensation. After driving it for about 15 minutes, though, it usually stops.
Old Feb 17, 2014 | 08:24 PM
RROLDSX's Avatar
Well known tips is to drill a 3/16" hole in the lowest point of your muffler (if it already doesn't have one) to drain the water from the muffler when sitting. It saves the muffler from premature rusting.
The engine needs to come up to full operating temp for about 15 minutes to clear it.
Old Feb 17, 2014 | 08:35 PM
All cars do this.
How long to warm it up? Until the tips of the exhaust pipes feel hot.
C'mon.
Old Feb 17, 2014 | 08:44 PM
76olds's Avatar
Hookers under Hood
[QUOTE=RROLDSX;656251]Well known tips is to drill a 3/16" hole in the lowest point of your muffler (if it already doesn't have one) to drain the water from the muffler when sitting. It saves the muffler from premature rusting.
X2 or use a center punch if you don't have a drill. get in er' warm er' up, in this case never put er' away dripin wet
Old Feb 18, 2014 | 09:04 AM
miko442's Avatar
Originally Posted by mdchanic
all cars do this.
C'mon.
- eric
ouch!
Old Feb 18, 2014 | 09:18 AM
Professur's Avatar
So .. nobody's going to tell him to take his wife's hairdryer to it? You guys are no fun at all.
Old Feb 18, 2014 | 04:44 PM
jag1886's Avatar
You just need to take it out and drive it for about 40 miles, I've pulled mufflers off of cars that must have had a gallon of water in them, you must do a lot of short trips and the mufflers are full of water because you are not getting the exhaust system hot enough to boil out the water. Old OE mufflers used to have a small hole drilled in the bottom of the muffler to let excess water run out, I'm sure Ralph Nader got rid of that.
Old Feb 18, 2014 | 05:08 PM
76olds's Avatar
Hookers under Hood
They only put the holes in the lifetime warranty mufflers. I wonder Y . You could always put your wifes curling iron in and boil it out, Professur now C what you started !!!
Old Feb 18, 2014 | 05:25 PM
Actually it mentions it in my owners manual to clear the holes periodically.
Old Feb 19, 2014 | 03:28 PM
63super88's Avatar
All cars, especially non daily drivers, naturally have some cold air in there that will form some condensation as we all know but i think its the lower quality of modern fuels + ethanol doesn't help I guess. now if the car still does it noticeably after some miles of drive then there might either be excess water in the muffler, or your not burning right somehow but that's doubtful.
Old Feb 19, 2014 | 07:34 PM
Originally Posted by 63super88
... the lower quality of modern fuels + ethanol doesn't help I guess.
You guess wrong.
The amount of water vapor produced by burning gasoline or gasahol, per unit of fuel, is the same.
The amount of water produced per unit of air is more for gasahol, because each molecule of ethanol already contains an oxygen atom, so less oxygen has to come from the air in order to make water.
Overall, though, the energy of the fuel is derived from the number of carbon atoms oxidized to CO2, and so long as the number is the same, it doesn't matter whether they come from ethanol or from medium chain hydrocarbons, and the general formula of CH4 + 2(O2) → CO2 + 2(H20) holds true.
Old Feb 19, 2014 | 09:54 PM
BILL DEMMER's Avatar
Just the facts...
Thanks,
Mike
we're not talking stanley steamer here, are we? if you're getting a lot of steam, you may have another issue.
bill
Old Feb 20, 2014 | 12:49 AM
Killian_Mörder's Avatar
If there isn't any dramatic coolant loss, they've nothing to worry about
Originally Posted by 76olds
...You could always put your wifes curling iron in...!!!
Oh, that wasn't nice
Originally Posted by MDchanic
All cars do this...C'mon...
Those youngtimers have mostly seen cars equipped with catylitic converters. When they get their hands on something without one, it's like a young girl getting frightened to near death when the first period happens.
I ended up having to teach my kids how to use a dial-up phone, because they've only seen them with pushbuttons
...The amount of water vapor produced by burning gasoline or gasahol, per unit of fuel, is the same.
The amount of water produced per unit of air is more for gasahol, because each molecule of ethanol already contains an oxygen atom, so less oxygen has to come from the air in order to make water...
Right, Sir. Nobody stops a passenger jet to check the level of coolant, simply because condensation is found in the exhaust
Old Feb 20, 2014 | 03:07 AM
Doesn't matter. Catalytic converters do not affect the water content of the exhaust.
A modern car with a catalytic will produce the same amount of water vapor per unit of gasoline burned as an older car.
In fact, I regularly see modern cars pulling away from a stoplight uphill (a particular one on my way to work), pouring about a pint of liquid water out the exhaust and onto the street as they do so.
That's why the snide comment (and I had initially typed "Duh." and thought better of it): EVERY car does this. Water vapor is an inherent product of ALL combustion. This is not new. If you want all of the water out of your exhaust system, you need to heat it up enough to evaporate all of the water. This is extremely basic and has not changed since cars were invented, so it is a bit odd to me how many people post questions on here as though the question were an entirely new phenomenon they've discovered (and, yes, it does recur regularly).
Old Feb 21, 2014 | 01:22 AM
As the exhaust system cools down, the moisture in the gases found in there will have to go somewhere and will collect on any surrounding object, just like getting a beer out of the fridge, on a humid day, and watching the bottle start to sweat
Old Feb 21, 2014 | 04:34 AM
Sampson's Avatar
Most people do not think about how much water is in the air unless it is raining! A 25 hp air compressor operating continuously at roughly 100 cfm will produce approximately 18 gallons of water per day:
Old Feb 21, 2014 | 04:39 AM
Sampson's Avatar
Great illustration! I had to go get a beer out of the fridge to conduct his experiment myself. Like any good scientist I looked for repeatable results. Seems this works every time and with every brand of beer I have tried
Old Feb 21, 2014 | 05:45 AM
Nothing better than a science experiment.
atkinsom
May 29, 2013 06:39 PM
65OldsDelta88SuperRocket
Oct 27, 2011 09:16 PM
Chuck C
Sep 1, 2004 07:37 PM
EdsDelta
Jul 22, 2004 11:46 AM
