Difference between outer and inner tie rods
Old February 8th, 2014, 06:34 PM
Once Olds Always Olds
Troys Toy 70's Avatar
I have new Moog tie rods that I recently painted. I kept the outer paired together, and the inner paired together; however, when I hung them in the garage, I forgot which pair I hung where. So, how can you tell the difference? The only difference that I can tell is that one pair has two or three more threads. HELP :,
Troys Toy 70 is offline
Old February 8th, 2014, 07:29 PM
Full-time Taxpayer
Qwik71442's Avatar
The outers have the grease zerk in the center of the joint and the inners have the grease zerk on the side or end of the joint. If they are reversed you will not be able to grease them properly.
Qwik71442 is online now
Old February 8th, 2014, 07:35 PM
bassinguy's Avatar
Question
Won' t one end be a right hand thread and the other a left hand thread?
bassinguy is offline
Old February 8th, 2014, 07:45 PM
dc2x4drvr's Avatar
Yup
dc2x4drvr is offline
Old February 8th, 2014, 07:55 PM
The zerks are in the centre on both sets. The correct answer is the threads for Moogs. Inners have reverse threads. Found an old post from 2010, and was checking this solution down in the garage, while you guys were answering. Thanks for the help
Greg Rogers
November 12th, 2014 06:01 PM
shovel55
March 3rd, 2013 01:18 AM
shovel55
October 1st, 2012 12:06 AM
shovel55
September 30th, 2012 11:53 PM
droldsmorland
July 26th, 2012 12:35 PM
Quick Reply: Difference between outer and inner tie rods
