Difference between outer and inner tie rods
Old Feb 8, 2014 | 06:34 PM
Troys Toy 70's Avatar
Once Olds Always Olds
I have new Moog tie rods that I recently painted. I kept the outer paired together, and the inner paired together; however, when I hung them in the garage, I forgot which pair I hung where. So, how can you tell the difference? The only difference that I can tell is that one pair has two or three more threads. HELP :,
Old Feb 8, 2014 | 07:29 PM
Qwik71442's Avatar
Full-time Taxpayer
The outers have the grease zerk in the center of the joint and the inners have the grease zerk on the side or end of the joint. If they are reversed you will not be able to grease them properly.
Old Feb 8, 2014 | 07:35 PM
bassinguy's Avatar
Question
Won' t one end be a right hand thread and the other a left hand thread?
Old Feb 8, 2014 | 07:45 PM
dc2x4drvr's Avatar
Yup
Old Feb 8, 2014 | 07:55 PM
The zerks are in the centre on both sets. The correct answer is the threads for Moogs. Inners have reverse threads. Found an old post from 2010, and was checking this solution down in the garage, while you guys were answering. Thanks for the help
Greg Rogers
Nov 12, 2014 06:01 PM
shovel55
Mar 3, 2013 01:18 AM
shovel55
Oct 1, 2012 12:06 AM
shovel55
Sep 30, 2012 11:53 PM
droldsmorland
Jul 26, 2012 12:35 PM
