Cribbing Blocks (poor mans lift)
Old Dec 20, 2013 | 10:58 AM
Mr Nick's Avatar
Thought I would share a little project I did this summer. I had the itch for a lift recently, and a friends father is selling a hardly used one pretty cheap. So I had to do something to prevent myself from spending the money on it. My garage has a support beam, so my lift height would have been pretty low anyway.
I made these cribbing blocks by following the instructions found here:
http://www.myturbodiesel.com/1000q/multi/wood-block.htm
The main thing I did different, was add 2 more pieces to the bottom of the 2nd level, to keep them locked in place and prevent movement. Not that it would slide around anyway, but it's simple peace of mind.
I can use the floor jack to get the car onto the first level. Then I slide some 12" wide lumber under the jack to lift it to the next level. I will replace them with wider pieces, as they currently aren't much wider than the wheels on the jack and I'm afraid an edge may split while lifting.
I am about 6'6" and can comfortably reach the distributor, I would think anybody not as tall as myself might find working under the hood a bit difficult at this height. Could build another block to stand on!
Build and use these at your own risk!!!!
Old Dec 20, 2013 | 11:05 AM
Cool.
Old Dec 20, 2013 | 11:13 AM
Cribbing is a tried and true method of raising and keeping raised all kinds of stuff, including buildings and wrecks.
Only downside: In case of emergency, that car's going nowhere fast.
Old Dec 20, 2013 | 11:20 AM
Nice, thanks for posting
Old Dec 20, 2013 | 11:24 AM
Mr Nick's Avatar
Thanks for the compliments guys!
Also added another shop light mounted at an angle, for better lighting under the hood. There was a light directly over the hood, but with the hood up it was useless.
Old Dec 20, 2013 | 11:29 AM
coppercutlass's Avatar
Chevy budget Olds powered
I saw this on one of the fb sites I think you posted it. I'm going to be doing this. As I ocasionally have to do exhaust and trans work on my car. I hate doing transmissions with a car on jack stands. I can't get it high enough . This will help that lol.
Old Dec 20, 2013 | 11:34 AM
Love the light, That way I can see the blood running down my shirt when I crack my head on the tooth
Old Dec 20, 2013 | 11:48 AM
Originally Posted by coppercutlass
I'm going to be doing this. As I ocasionally have to do exhaust and trans work on my car. I hate doing transmissions with a car on jack stands. I can't get it high enough.
Or you could just do what I did in college when I had to swap a trans (and, no, resting the car on a pile of rocks and cinderblocks is not recommended by leading safety authorities):
Oh, to be young again...
Old Dec 20, 2013 | 11:54 AM
RROLDSX's Avatar
Saving your noodle with noodles
Jamesbo:
I used pieces of kids pools noodles to pad the sharp points and the tooth.
I've saved my head a couple of times already.
Old Dec 20, 2013 | 11:55 AM
Professur's Avatar
How much higher is that over just using a set of ramps? I put 3 2x12s of different lengths under my ramps so that they add some inches, but I can still get it outta dodge in a hurry if need be. At 5'5, I need a bloody step ladder to reach the air cleaner wingnut anyhow, so it's no great inconvenience.
Old Dec 20, 2013 | 11:57 AM
My preferred thing was a railroad tie, chunked into 4 pieces.
Old Dec 20, 2013 | 11:59 AM
Mr Nick's Avatar
Yep, I posted the same pic on the Fast Olds FB page.
Mine are 12" high, could be built higher or slide some planks under the blocks for more height.
Old Dec 20, 2013 | 12:00 PM
Originally Posted by RROLDSX
Jamesbo:
Now that's using your head
Old Dec 20, 2013 | 12:34 PM
... Or, as they say, using your noodle.
Old Dec 20, 2013 | 02:31 PM
Is that cutlass pink lol. Yeah I grew up with my dad telling the story of how his buddy died doing a clutch with out jack stands and the car fell and he dided. I won't use anything but jack stands or these blocks now lol.
Old Dec 20, 2013 | 02:38 PM
Professur's Avatar
I retired dad's old steel ramps about 5 years back. Prior to that I'd always kept a block of 6x6 under the pad of each one to carry the weight. There's only two levels of paranoia: rampant ... and insufficient.
I'm certainly not the only one who insists on multiple layers of protection. Working on brakes ... The wheel gets shoved under the control arm, a stand under a hard point, and the jack left in place with the weight eased off. I've worked on too many old cars where the jack punched through to ever trust one point alone.
Old Dec 20, 2013 | 05:01 PM
Octania's Avatar
what are the wheels on that elevated car?
Old Dec 22, 2013 | 05:41 PM
Mr Nick's Avatar
BG Rod Works Gasser. If you do a Google Image search, my car comes up
patmills
Brakes/Hydraulic Systems
Aug 15, 2010 07:15 PM
Shebe72
Jul 5, 2010 08:11 AM
55jes
May 13, 2010 08:36 PM
DAN76
Jul 28, 2009 02:13 AM
jensenracing77
May 1, 2009 02:35 PM
