Delux Spinner caps
Old Sep 27, 2013 | 02:45 AM
lazy394's Avatar
Delux Spinner caps
looking for advise, I have the deluxe spinners on my 59 and they squeak when I drive.
I replaced the clips but the problem got worse as the replacements are loose on the cap and now they rattle too
Old Sep 27, 2013 | 04:30 AM
HonestDave's Avatar
Closest thing I had was a 65 Valant Rag that had hubcaps making ticking noises. No matter what I tried I couldn't make it stop. Finally switched to mags, then smashed the car up doing some seriously bad teenage driving....that fixed the noise problem, but I don't recommend it.
Old Sep 27, 2013 | 05:27 AM
wmachine's Avatar
Trying to remember member
Now *that* made me laugh!
I have factory wire covers on my Jetstar 1 and one side front clicks only on left hand turns. Best I can do with them. Cars tend to throw these covers on the highway too, but I've not had that happen. I wouldn't keep them on the car, but that is what it came with, so they stay!
Old Sep 27, 2013 | 06:25 AM
HonestDave's Avatar
Now that you mention it, the Valiant used to throw a wheel cover. I can sort of remember having to comb the ditches looking for it from time to time. So long ago I'd forgotten. Maybe 34 years ago !!
Where DOES the time go?
Old Sep 28, 2013 | 12:10 AM
lazy394's Avatar
Yup that will fix them lol
Old Sep 28, 2013 | 12:12 AM
lazy394's Avatar
Im wondering if the tyres are hitting the edge, because as you turn the tyres deform and can hit Hmmm
Old Sep 28, 2013 | 04:30 AM
HonestDave's Avatar
For some years my wife and I drove 63 and 64 Buick Rivieras. They had some spinner spoked caps that were quiet. Great big steel claws held them on. The cheaper ones have just got bent tin for grabbing the rim edge. Maybe that made a difference.
Old Sep 28, 2013 | 09:35 AM
wmachine's Avatar
Actually it is a slight (and normal) wheel flex that is the culprit.
Useally wheel covers have "spring" clips to attach them to the wheels. This is how you can "pop" them on by compressing the clips. But these clips also absorb normal wheel flex. Some heavier covers are more rigid in the attachment attempting to keep the cover on the wheels. But they are then less forgiving to the wheel flex.
Old Sep 29, 2013 | 01:15 AM
If your hub caps are in good condition and a poor fit isn't the culprit then I suggest using a little bit of brake caliper grease between the wheel and the hub cap. Hopefully this will muffle any sound coming from the hub cap rubbing against the wheel. Of course, it might cause your hub caps to get thrown off of the car once you get up to driving speed too. Just a thought...
Old Sep 29, 2013 | 07:29 AM
wmachine's Avatar
That will definitely get rid if the noise......
jjcus
Oct 18, 2014 10:58 PM
Nov 13, 2012 01:01 PM
65-442
Mar 23, 2012 11:37 AM
tacodave
Jun 19, 2010 08:59 PM
whitey
Mar 10, 2010 03:18 PM
