Wall of shame
Old August 22nd, 2018, 06:59 AM
  #361
Justin
oldstata's Avatar
oldstata is offline
Old September 14th, 2018, 02:04 PM
  #362
Justin
oldstata's Avatar
oldstata is offline
Old September 14th, 2018, 06:59 PM
  #363
svnt442's Avatar
Originally Posted by oldstata
Sure....what's a little more flow gonna hurt.
svnt442 is offline
Old October 13th, 2018, 09:09 AM
  #364
Justin
oldstata's Avatar
oldstata is offline
Old October 13th, 2018, 09:11 AM
  #365
Justin
oldstata's Avatar
My brakes were done two weeks ago ! I don’t need brakes
oldstata is offline
Old October 14th, 2018, 02:01 AM
  #366
svnt442's Avatar
What....HOW?!?!?
svnt442 is offline
Old October 14th, 2018, 07:41 AM
  #367
Justin
oldstata's Avatar
Originally Posted by svnt442
What....HOW?!?!?
honestly I don’t know, there is no sign of impact on suspension or wheel, I was talking to customer and she said brake were just completed a few weeks prior, pads were wore out 2/32 parts did look new, I am thinking cheap china parts, customer declined work and is bringing a replacement rotor from the shop that preformed brake job
oldstata is offline
Old October 16th, 2018, 07:39 PM
  #368
Oh no, not again...
Nailheadcanuck's Avatar
Location: Sherwood Park, Alberta, in the Great White North
Interesting thread, I haven't laughed this hard in a while.
The scary thing is when cars with major structural issues like some of those depicted here are sold as solid transportation to people who can least afford to fix them.
Nailheadcanuck is offline
Old October 23rd, 2018, 02:02 PM
  #369
Justin
oldstata's Avatar
Fb post 😯
oldstata is offline
Old October 23rd, 2018, 02:59 PM
  #370
What an idiot.
Everyone knows you put the duct tape on the INSIDE.
MDchanic is offline
Old October 24th, 2018, 06:15 AM
  #371
Jeff
Weezer's Avatar
A friend of mine once had his car at the tire shop, and the tech told him he had a "Maypop". My friend gave him a confused look, asked what the hell a "Maypop" is, and the tech grinned and showed him. It was a bubble on the sidewall of the tire. The tire "may pop."
Weezer is offline
Old January 23rd, 2019, 07:52 PM
  #372
Funkwagon455's Avatar
Some masterful bodywork noticed at our local Wally-world
Funkwagon455 is offline
Old January 27th, 2019, 06:59 PM
  #373
indy500's Avatar
Spent a good half hour going through these. Good fun though I'm not sure what I'm looking at in a few of the pictures.
The funniest story I heard was told to me by a coworker when I first started working 30 years ago. Another coworker was doing something where he needed the accelerator pressed down a bit so he wedged a block of wood between the brake pedal and the accelerator. He left the wood there and his wife got in the car, started it and shifted into reverse. Pushing down the brake just resulted in going faster in reverse. She went down their driveway, and then up the neighbor's drive across the street, into their garage and busted through the back wall into the neighbor's back yard. There, she proceeded to do donuts in reverse. She continued doing donuts in their backyard. When asked why she didn't just turn off the ignition, she said the only thing she could think at the time was 'I just filled up yesterday!'
indy500 is offline
Old January 27th, 2019, 09:02 PM
  #374
RandyS's Avatar
Man, I haven't heard that term in 50 years!!
RandyS is offline
Old January 29th, 2019, 06:08 AM
  #375
toymobile's Avatar
easy way to tighten lines
toymobile is offline
Old January 29th, 2019, 07:52 AM
  #376
344879M363895
70-442-W30's Avatar
That's NASCAR style. Get back in the race!
70-442-W30 is offline
Old January 29th, 2019, 08:45 AM
  #377
Originally Posted by toymobile
Not car related but I saw this once on a pilot line on a old furnace. They just left the wrench on it.
Greg Rogers is offline
Old July 21st, 2019, 09:59 AM
  #378
Rocketguy's Avatar
This guy comes into my shop with a 2015 F-250 and says "I was getting off the freeway and when I hit the brakes the pedal just went to the floor".
He pulled in using his trailer brakes. He was towing a 9000lb trailer.
Rocketguy is offline
Old July 23rd, 2019, 01:27 PM
  #379
Schurkey's Avatar
Originally Posted by Delta88conv455
Well this is what happens when you think that the bellhousing bolts are tightened enough...
My car came here in Finland at 2012 from US and someone at that end did not know how to tighten bolts
Originally Posted by edzolz
Looks more like it took a heavy bounce and broke the bell housing. I don't see how loose bolts would break that area from the trans. A heavy shock load is more believable to me.
Dropped when loaded/unloaded into the freighter that carried it from USA to Finland. "Shipping damage".
Originally Posted by MDchanic
And, yes, both pistons of the master cylinder, which are different sizes, are feeding the same single brake line.
As for the copper, there is copper brake line that is legal. It comes in bulk rolls and is not cheap, but if you are redoing a number of cars, it is much easier to work with than steel, and it is immune to salt.
Different size master cylinder pistons? That's all-new to me. The only master cylinders I know of that have different sized pistons are the Quick Take-Up jobs for low-drag front calipers, and the larger bore supplies volume but minimal pressure. The actual braking is done with regular primary and secondary pistons of the same size.
There is no "copper" brake tubing. There's Copper-Nickel alloy that's used for brake and fuel tubing. I've never worked with it.
I've got a Pinto rotor where the fins are showing, and the braking surface broke away from the hub...but there's been plenty of others just like it posted here. As usual, the car drove into the shop. "The brakes have been grinding for awhile..."
My own story: Driving a 1980 Honda Civic 1300. The 1500cc version has iron block and a catalytic converter. The 1300 (mine) has all-aluminum engine, and no need for a catalyst.
58,xxx miles, driving in fifth gear at ~70 mph down the interstate at midnight in February. Engine stalls, oil light comes on, I instantly kick the clutch and coast to the side of the road.
Discover upon teardown that four main bearings look like new. Three rod bearings look like new. One rod bearing is burnt black, worn so sharp you could shave with it, and the connecting rod is in four main pieces, BUT NEITHER ROD BOLT BROKE. (If you could undo the rod bolts, it'd be six pieces plus the bolts and nuts) It's the only broken connecting rod I've ever seen that DIDN'T fail the bolts. (I've seen photos of others, but never saw 'em in real life.) At the time--1985--I took Polaroid photos of the rod, and the original photo got singed. All I have now is the damaged photo, which I then took a digital photo of. So here's a picture-of-a-picture complete with singe-marks.
Naturally, the rod pieces blew a hole in the block directly in-line with the edge of the oil filter. I kept the piece of block, plus the rod fragments for years. Lost them some time ago.
Schurkey is offline
Old July 28th, 2019, 05:30 AM
  #380
toymobile's Avatar
This is real neet/
Old July 30th, 2019, 08:24 PM
  #381
oldolds88's Avatar
I knew a guy that beat the das an his nova 2dr, took out the rt seat and hauled his dirt bike that way.
oldolds88 is online now
Old July 31st, 2019, 09:43 AM
  #382
Schurkey's Avatar
Huh?
Schurkey is offline
Old July 31st, 2019, 07:57 PM
  #383
FN723's Avatar
I have a four door nova sitting in the back woods rotting. The bike would probably fit better.
FN723 is offline
Old August 3rd, 2019, 09:23 AM
  #384
Destructor's Avatar
Breakerless SE electronic ignition trigger. Ordered from two places, after over a month of waiting from each place I called and canced the orders.
Destructor is offline
Old August 6th, 2019, 12:44 PM
  #385
toymobile's Avatar
Old August 19th, 2019, 04:08 PM
  #386
Justin
oldstata's Avatar
Omg
oldstata is offline
Old August 19th, 2019, 04:30 PM
  #387
RandyS's Avatar
What would cause something like that to happen?
RandyS is offline
Old August 19th, 2019, 04:58 PM
  #388
Justin
oldstata's Avatar
Side wall impact causes bubbles in tire I believe this was ran flat and inflated and has multiple inner stores in the rubber layers
oldstata is offline
Old August 19th, 2019, 04:59 PM
  #389
Majored in rear tire demo
2Olds4U's Avatar
A tire that was driven low/flat and broke the sidewall belts. A needle in any one of them would be scary!
2Olds4U is offline
Old August 19th, 2019, 05:09 PM
  #390
svnt442's Avatar
I was thinking it was from parking too close to the curb all the time, but running on a low tire is much more likely.
svnt442 is offline
Old August 20th, 2019, 11:27 AM
  #391
Jeff
Weezer's Avatar
MAYPOPS!
As in, that tire may pop.
Weezer is offline
Old August 20th, 2019, 12:15 PM
  #392
Some call me, Tim
Tim75's Avatar
Why does this remind me of Stripe from Gremlins? Or Agent Smith at the end of The Matrix?
Omg
Tim75 is offline
Old October 8th, 2019, 08:11 AM
  #393
Justin
oldstata's Avatar
Something just shouldn’t be
oldstata is offline
Old October 14th, 2019, 12:36 PM
  #394
zeeke's Avatar
I don't know if this is more of an advisement or a wall of shame item.
Kept smelling fuel on the Cutlass and couldn't figure it out. All the lines were new so after a long trip I popped the hood and saw the intake nipple on the fuel pump was wet. I'm guessing in the past it evaporated before I could find it. Anyway thought the rubber fuel line was loose because I was able to roll it back clock wise and counter clock wise. wouldn't tighten anymore. When I tried to pull it off the nipple came out of the fuel pump. Luckily the car didn't go on fire. No Idea what make as it was on the Frankin Cutlass when I bought it.
One
Two
Holy S!@#
zeeke is offline
Old October 14th, 2019, 12:41 PM
  #395
Justin
oldstata's Avatar
One
Two
Holy S!@#
My 330 did that same thing not sure if it was original pump but they seem just pressed in from factor
oldstata is offline
Old November 8th, 2019, 08:32 PM
  #396
..Quarter million dollar Porsche....BAD DOG!!
Old November 12th, 2019, 05:08 AM
  #397
toymobile's Avatar
Old November 12th, 2019, 05:48 AM
  #398
I'd give them a B+ for ingenuity!!
Old November 12th, 2019, 08:26 AM
  #399
Jeff
Weezer's Avatar
Holy sh*t, that's a "hurry up and pass that moron" situation!
Weezer is offline
Old February 20th, 2022, 02:20 PM
  #400
This made me slightly nauseous!😅. It would be slightly less offensive if it were not advertised as an Olds..
Quick Reply: Wall of shame
