71 442 trunk light
Old Mar 18, 2013 | 05:22 PM
dfire25's Avatar
"Trying to fix her right"
71 442 trunk light
Hi guys,
I purchased a trunk light for my 71 442 and need help on where to install it. I looked for pictures but they are hard to find, in fact I haven't found any. The light came "clipped" to a metal bracket with screw holes, but it doesn't fit anywhere with the bracket. If I removed the bracket and use the clips to install it, (see pics) it works ok. Is this correct, or do I need the bracket? Also, is there a wireing harnes that is used for the light, and where does or plug into? Thanks in advanced for the help.
Old Mar 18, 2013 | 05:57 PM
Gary's 2 442-S's Avatar
Gary
You do have that part of it mounted correctly. there is a single orange wire with a connector that attaches to it. it comes from the wiring harness in the trunk toward the back. I will send u a picture of it shortly.
Old Mar 18, 2013 | 06:57 PM
Gary
Old Mar 18, 2013 | 07:19 PM
Rocketbrian's Avatar
Due to differences in the trunk hinge area, Cutlass "S"/442 fastbacks don't require the bracket, only Supremes need to use it. I had the same question when I bought my 442 and couldn't figure out how to mount the light.
Old Mar 18, 2013 | 09:18 PM
dfire25's Avatar
Thanks for the info guys. I'll have to look a little harder for that wire. I think I have that flat plug, does the wire lo from there?
shamusj
Apr 7, 2018 08:10 AM
BeenThere
Jul 18, 2015 11:39 AM
jensenracing77
Dec 11, 2013 08:22 AM
Ddbord
May 6, 2013 06:12 AM
5998DownUnder
Ninety-Eight
Apr 19, 2013 05:56 PM
