1970 oil pressure guage
Old Mar 2, 2013 | 02:58 PM
charlierogers's Avatar
is this the correct/stock oil pressure sender for the rally pack? need to be sure before i bid!
thanks charlie,,,
http://www.ebay.com/itm/151001596202...84.m1438.l2649
Old Mar 2, 2013 | 03:19 PM
pogo69's Avatar
morgan
thanks charlie,,,
It might work...but it is not the correct part
Old Mar 2, 2013 | 05:02 PM
covertolds's Avatar
That is the correct sender for 1970.
Old Mar 2, 2013 | 05:08 PM
stevengerard's Avatar
looks correct to me, looks like its been painted though, but that shouldn't matter unless you are looking for NOS. They make repos, unfortunately they don't look exact but they are a lot lot cheaper
Old Mar 2, 2013 | 05:17 PM
octania tipped me off to this, i have the repo on mine which came with the car. i thought mine was correct/stock. have looked at alot of 70-72 442's and have never seen the ebay one! still learning
Old Mar 2, 2013 | 05:18 PM
pogo69's Avatar
morgan
Not according to parts#
6462137 is the correct part not 6462142 (1966-67)
Old Mar 2, 2013 | 06:25 PM
is this possibly a superceded part # ?
Old Mar 2, 2013 | 06:56 PM
pogo69's Avatar
morgan
They seem to be different parts because they are for different engines
370801 is the new number for the 68-70 but i can't see anything in the book that the ebay part is correct for anything after 1967
Old Mar 2, 2013 | 07:08 PM
pogo69's Avatar
morgan
I see the price is over 200 bucks...a few people obviously want it bad, I myself wouldnt pay that much because the numbers are different...but that doesn't mean it won't work
Old Mar 2, 2013 | 08:10 PM
$410 yikes,
Old Mar 2, 2013 | 08:16 PM
pogo69's Avatar
morgan
$410 yikes,
Those little things are pricey....for that kind of money I would definitly make sure the number matched
Old Mar 2, 2013 | 09:47 PM
70Post's Avatar
There seems to be two units of these NOS styles that get sold out there (same appearance for both..like the one linked to). One difference b/n the two part #'s may be one is for 0-80 psi and the other is for 0-60 psi.
Old Mar 3, 2013 | 07:47 PM
for $410 I wouldn't buy it even if it was the exact part number - they come up for sale occasionally much cheaper than that.
Old Mar 3, 2013 | 09:21 PM
i will be keepin my eyes peeled for one. i will not be spending 400 bucks on it though!
Old Mar 3, 2013 | 10:55 PM
66-3X2 442's Avatar
The 70 sender was painted black. I'm not sure about other years.
Old Mar 4, 2013 | 08:04 AM
StickW31's Avatar
yes that is 100% correct
Old Mar 4, 2013 | 08:10 AM
StickW31's Avatar
https://classicoldsmobile.com/forums...rally-pac.html
these items get pricey. ill take $400 for this one.
Old Mar 4, 2013 | 08:54 AM
69'442's Avatar
So on a 1970 442 it should be painted black not just the yellow zinc plating?
Old Mar 4, 2013 | 09:07 AM
neither of mine looked like they were painted black, looked like a dirty cadmium plating - Ill have to check again.
Old Mar 4, 2013 | 09:11 AM
66-3X2 442's Avatar
The 70 W-30 I just sold had the sender painted black. When I posted pictures of the engine,Brian Trick I think commented about the sender being the correct black. Maybe Brian will see this and comment.
Old Mar 4, 2013 | 09:34 AM
70Post's Avatar
I'll "second" the black finish on the '70 units. Who knows, however, if ALL the '70 cars had this finish on the sender or not? Maybe Olds transitioned to unpainted units at some point in '70...'71?? Maybe it was the AC/Delco division that made the decision since they apparently manufactured this part.
Old Mar 4, 2013 | 09:36 AM
I'd prefer black as it would be easier to spray them black than to re-plate them
One is a November 69 build the other is an April 70 build. I'll try to check.
Old Mar 5, 2013 | 11:35 AM
ROCKET VAPOR's Avatar
Lance
FWIW, The original one on my '70 is painted black as well.
Old Mar 5, 2013 | 11:46 AM
That's good to know, is it flat, semi, or gloss?
Old Mar 5, 2013 | 11:47 AM
69'442's Avatar
Can someone please post a picture of a black one.
Old Mar 5, 2013 | 11:54 AM
Lance
Semi-black
Old Mar 5, 2013 | 11:56 AM
66-3X2 442's Avatar
I do not need any comments on the gold paint,not my doing.
Old Mar 5, 2013 | 12:35 PM
sent pm!!
Old Mar 5, 2013 | 12:44 PM
StickW31's Avatar
sent pm!!
PM replied Charlie
Old Mar 5, 2013 | 03:34 PM
69442murph's Avatar
have an original sending unit from my 69 HO., it is also painted black with some red engine overspray...
Old Mar 5, 2013 | 03:47 PM
  #31
66-3X2 442's Avatar
That's what I'm talkin bout,good ole information.
Old Mar 6, 2013 | 05:30 AM
  #32
69'442's Avatar
Do you guys use teflon tape on the threads of the sending unit or no. Something about grounding.
Old Mar 6, 2013 | 06:30 AM
  #33
I didn't use the tape, I think it says in the engine assembly manual not to but not sure if it was a grounding issue, but that sounds correct.
Old Mar 6, 2013 | 06:47 AM
  #34
Lance
My original assembly line issued 80# P/N 6462137 oil pressure sending unit for rally pac gauges.
Keep in mind that although correct in function, a factory service replacement part will have a different julian date code stamped into the body of the sending unit. Stamped day of the year "XXX" and last digit of the year "X".
Old Mar 6, 2013 | 07:13 AM
  #35
Thanks, first thing I do this spring is paint the sending unit semi black to match!
Old Mar 6, 2013 | 07:31 AM
  #36
69'442's Avatar
Thanks for the pics. I pulled mine last night and painted it semi gloss today. It's a newer one but at least it's the right color now.
Old Mar 6, 2013 | 02:11 PM
  #37
Del70's Avatar
Looked at the vintage road test videos on youtb of the 68 hust olds and 71 442 30 . The 71 sending unit is hard to see but it looks like it has platting. The 68 hust sending unit is easily visible. Looks like it too has platting. – Lots of good info in videos -
Old Mar 6, 2013 | 02:39 PM
  #38
covertolds's Avatar
Here's some photos of a couple that I took some time back. I've since sold one to an active member in this thread. I still have the black one, but it's not for sale.
Old Mar 6, 2013 | 02:42 PM
  #39
joesw31's Avatar
Good topic here. It depends on when the car was built as not all 1970 units were painted black. My December 69 built w31 has a cad plated unit and my April built W31 has a black unit. Both have the same part number, but the dates are different. Again, both units are original to there respected cars. So, when did the change take place; I'm not sure. Was it because the car was built during the strike? Not sure.
Old Mar 6, 2013 | 02:54 PM
  #40
pogo69's Avatar
morgan
mine (6462137 029 9 ) also appears to have been black also no spade terminal just a nut
