1965 Cutlass 442 A/C Cover Plate
Does anyone know if somebody makes cover plates to go over the firewall holes that are left when someone removes the A/C from a car? I have two big holes in my firewall (upper left in picture). One has blue plastic, as a temporary cover. I'm trying to avoid cutting sheet metal and covering it that way, but may have no choice.
There is an A/C delete panel for the '68 to '72 "A" body cars.
I don't know of one for the '64/65 "A" body.
Did you add the factory heater box after you took the A/C off ?
My '64 had a hole in the lower left, behind the wheel house and another one on the firewall, just don't remember the ones you have. Maybe '65 is different.
Gene
Gene
Gene
Gene
