1969 442 convertible question / radiator core support?
Old Sep 11, 2012 | 07:47 AM
Flgaurban06's Avatar
Guys, I found a radiator core support from a 69 cutlass. Question: is it the same one for my 442 69 convertible ( will it fit/interchangable )?
Old Sep 11, 2012 | 10:02 AM
69442C's Avatar
Yes.
Old Sep 11, 2012 | 10:58 AM
Jonb442's Avatar
The only difference would be the saddles for the radiator; they're longer if you have a four-core radiator. The fan shroud brackets are different too in that case. The saddles are reproduced and the brackets may be as well; if not they can probably be fabricated.
-Jon
Old Sep 11, 2012 | 01:46 PM
-Jon
Of course the four row vs two/three row radiator difference is unrelated to the car being a convertible. Both top and bottom brackets for four row radiators are now reproduced.
Old Sep 11, 2012 | 05:02 PM
Jonb442's Avatar
Thanks Joe. I just meant that using a support from a Cutlass on a 442 might require that change. That's what I did and switched the saddles and brackets over from my rotten original.
-Jon
mcutlass1969
Mar 7, 2016 05:17 PM
Boilerz25
Jun 4, 2014 12:12 PM
Flgaurban06
Sep 3, 2012 11:44 AM
Flgaurban06
Aug 30, 2012 01:30 PM
SMOSLEY
Jun 6, 2008 12:33 PM
