Can anyone decode this data plate?
Old Jun 28, 2012 | 06:08 PM
JOHNNYOLDS442's Avatar
Olds Specialist LOL
All i know is the 48 sherwood green It's a 1970 cutlass "S" the car has in it now a 455 e head motor turbo 400 bucket seat auto with a black int
Uploaded with ImageShack.us
Old Jun 28, 2012 | 08:14 PM
jaunty75's Avatar
The "06A" means it was built in the first week of June 1970. That's a late-in-the-model-year build date.
For the rest, others will chime in soon with your answers.
Old Jun 28, 2012 | 08:16 PM
rcorrigan5's Avatar
Randy C.
ST 70 = style/model year = 1970
33687 = Oldsmobile (3) Cutlass (36) holiday coupe (87)
E = assembly plant = Linden NJ
14166 BDY = body number for that assembly plant
TR 937 = interior color and front seat type = ivory color with strato bucket seats
B80 = option code = exterior drip scalp molding
48 48 PNT = lower and upper body colors = sherwood green for both
06A = time build code = June (06), first week of that month (A), 1970
B84 = option code = exterior body side molding
B85 = option code = exterior belt molding
I'm not exactly sure what the difference is between body side moldings and belt moldings; hopefully, someone else can explain!
Randy C.
Old Jun 28, 2012 | 09:21 PM
Nufo's Avatar
B85 - Belt Moulding - That's the moulding at the top of the door where it meets the door window and quarter window...
Old Jun 28, 2012 | 09:36 PM
More specifically B85 is the WIDE molding as described. Required special sub mounting. Stainless moldings were about 1 1/4" wide.
Old Jun 29, 2012 | 03:49 AM
Olds Specialist LOL
Thanks all
Ivory int ?? it's black so it was changed it has a black headliner?
yes it has the wide moulding on the top of the doors and quarter.
what about engine? how do i tell what motor it came with?
Old Jun 29, 2012 | 12:07 PM
Originally Posted by JOHNNYOLDS442
Thanks all
Changing interior colors is not that hard. If it's black that's what a PO has done. Black interior is a color that will go with any color Olds exterior. If you want to go back to original, that can be done with some time, effort and $$$.
re: Engine. Look at the engine stamping pad just in front and below the #1 cylinder. If the last 6 digits of the number there are the last 6 of your VIN, you have the original engine.
The only other way to determine the original engine size would be if you have the original dealer invoices or build sheet. The 70 Cutlass S 33687 could have come with an 8 cylinder engine, but that's all the detail that's provided in the 1970 CSM.
Old Jun 29, 2012 | 02:21 PM
GAOldsman's Avatar
"Car"mudgeon
336 = Cutlass V8
335 = Cutlass L6
Old Jun 29, 2012 | 02:23 PM
GAOldsman's Avatar
"Car"mudgeon
'65 - '71 third digit VIN = even # = V8
'65 - '71 third digit VIN = odd # = 6 cyl
Old Jun 29, 2012 | 02:28 PM
Yup, Scott what I meant in my post was whether it was a 350 V8 or 455 V8. Guess I should have been more clear. Too bad they didn't have the coding like the 72.
So the VIN derivative on the stamping pad is going to be his best clue whether it's the original engine for the car
66 Olznut
Dec 13, 2013 03:34 PM
x2248344
Aug 10, 2012 04:18 AM
oldspower_68
Nov 24, 2011 08:37 AM
Boh2k
Sep 27, 2010 07:16 AM
rida142
Sep 3, 2007 02:33 AM
