What cfm
Old Nov 27, 2011 | 12:34 PM
aristellier's Avatar
What cfm
My last car a 1963 Dynamic 88 was running a Edelbrock 750cfm carb and ran great, my new car a 1963 Starfire has got an Edelbrock 600cfm carb. Is this going to be man enough for the high compression 394ci. It does make a big sucking noise when you floor it!! Just wondering what you think.
Old Nov 27, 2011 | 01:23 PM
Rickman48's Avatar
Should be fine everywhere but the Autoban, and I didn't hear about a bridge or tunnel, yet!!
Old Nov 27, 2011 | 07:15 PM
rocketraider's Avatar
Oldsdruid
Considering the original equipment Rochester 4GC was rated around 500 CFM or so, I'd say you got plenty!
Old Nov 28, 2011 | 11:24 PM
DeltaPace77's Avatar
You've maybe opened a few things up here. 1st is most carb manufacturers rate cfm flow at different negative pressures, and can also vary between 2bbl and 4bbl. Next would be head flow/cu in and rpm band. To simplify, if a 400 cube so so head flow low rpm street torque motor, 600 cfm carb should do it. For what sounds like a higher rpm/flow build you're doing, 750 4 bbl would be good. Cant stress enough the importance of dialing in carb and distributor tuning. Could make the difference of showing your tail lights or seeing theirs.
tim72
Jul 26, 2010 01:29 AM
Viz G
Aug 6, 2009 04:02 PM
delta881972
Jan 24, 2009 05:54 AM
fearthisrocket
Feb 18, 2008 06:19 AM
