Carb dashpot
Carb dashpot
I know this has been asked before (several times by others) but here goes. Does anybody have a carb dashpot and bracket they want to part with? It's for my '71 but I think at least '69 thru '73+, all models/engines, should be the same.
No, no, J - The dashpot & bracket is the thing at the top left of this picture:
Doesn't it look familiar?
That and the cruise servo should, as they were in that box of "junk" I bought from you a couple years back. Of course they were dirty and rusty back then........
Quadrajet (actually the 2-bbl has one too). I've seen it on other cars (1969-1972) and there's a section in the 1971 repair manual for properly adjusting it so I assume mine's missing. The holes and bolt are there in my intake where is should go.
Found one! Needs a little cleaning but I pushed the rod and it appears to work fine. How does $20 to your door sound? John
Cool! Looks like John found you a dash o' pot!
It looks about like the one I had got from J, but with a wire wheel on a Dremel, some deruster, cans of black and aluminum spray paint, it will look like mine in the picture above!
