interchangeability of parts
Old Nov 13, 2011 | 05:45 PM
projectheaven's Avatar
Hello,
I'm getting ready to part out a 1996 Impala that I received from a family member and I'm wondering if there is anything on the car that I can use on my 1972 cutlass convertible or supreme? Like the rear disc brakes, rear end, etc.......
I'm going to remove the lt1 and 4l60E and save it for a future project maybe in the future.
Thanks for your help
Old Nov 13, 2011 | 10:32 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
The rear end should swap. Just check the angle of the upper ears to be 100% sure. 73-up cutlass is a direct swap, but the 72 may have different ears.
The front spindles are also useful. Not a direct swap, but useable if you do the right combination of parts. Ball joint taper holes are different.
Springs should swap, as well.
69 Vert
May 13, 2014 07:43 AM
HouTXCutlass
Oct 4, 2010 11:54 AM
Alocatelli
Jul 24, 2007 09:17 PM
shaks 442 clone
Jul 23, 2007 11:46 AM
Dutch
Nov 8, 2006 05:11 AM
