Vent window weatherstrip install on 68 442?
Old July 23rd, 2011, 08:07 AM
Tom442's Avatar
Good morning all! I don't see anything in any of my manuals about wether or not to use weatherstrip adhesive in the vent window frame. What have you done when you did yours? Seems like it needs it, I havent tried screwing it back together yet, maybe that is enough to hold it in place?
Tom
68 442(fingers crossed)
70 f85
95 Aurora
Tom442 is offline
Old July 23rd, 2011, 08:42 AM
Lady72nRob71's Avatar
Can you tell if any adhesive was used originally?
Lady72nRob71 is offline
Old July 23rd, 2011, 09:15 AM
Tom442's Avatar
No, it doesn't look like they used adhesive from the factory. I guess the factory weatherstrip was probably a better fit than the after market stuff. I screwed the frame back together and it looks better....I am going to use a little adhesive.
Thanks Rob.
Tom
Tom442 is offline
Old July 23rd, 2011, 09:38 AM
1968Cutlassfallbrook's Avatar
how difficult were they to take apart as I'm going to have to do that to mine any tricks to getting that stainless cover off the frame without damage? Thanks
1968Cutlassfallbrook is offline
Old July 23rd, 2011, 12:00 PM
Tom442's Avatar
Well I took the drivers side apart and cleaned YEARS ago. I guess I threw out the old weather strip Fortunately, I left the passenger side together. Took it apart and found the 4 little metal clips that hold the thick, angled part of the weatherstrip...thats good...bad part is the clips were probably still on the one I threw out. Now either split the four between the sides...or track down more.
It is pretty easy to take apart. Of course you will have to have the vent window out of the door. One screw at the very tip that you access from the big door glass channel, then two screws on the lower horizontal part(it is riveted at the other end where the main glass channel is. Once the screws are out, it frees up the vent window which is then rotated about all the way open, then you can slide the shaft up and out. There are two stainless channels that can then slide off the window channel. The narrower one has a couple of spots where the stainless looks to be pressed or crimped down into two holes on the channel. You can use a small tool and tap it so it will let you slide the stainless up and out of the window channel. I will get some pics posted. NOW whose got the little clips pictured? (they obviously didnt come with the new weatherstrip)
Tom442
Tom442 is offline
Old July 23rd, 2011, 12:47 PM
Tom442's Avatar
So here is some detail pics of the stainless trim on the vent window. Drivers side slid right off but the passenger side I had to tap the stainless out from the window channel JUST Barely! So drivers side is done...now to find those clips.
Tom
68 442 (it will move faster soon)
70 F85
95 Aurora
Tom442 is offline
Old July 23rd, 2011, 01:17 PM
66-3X2 442's Avatar
Those clips are a bitoch to reuse. I really think all they were for was to hold the w/s in place till the glue dried. I just put a set in and the clips wouldn't hold,so I just glued them in. Once the glue drys,you're good to go. The frame I did had traces of glue,so I'm pretty sure they had both. You can't buy new frames and you have to have old ones re-chromed. The clips would not hold on the new chrome,that's why I didn't use them.
66-3X2 442 is offline
rsandhoff
January 18th, 2015 11:19 AM
BeenThere
December 28th, 2014 08:27 AM
bspaulding
July 29th, 2014 08:30 AM
Tom442
April 17th, 2012 01:08 PM
Tom442
July 23rd, 2011 07:23 PM
Quick Reply: Vent window weatherstrip install on 68 442?
