Foggy lower windshield???
Old Jul 3, 2011 | 08:27 AM
DeltaDevil88's Avatar
I have noticed at the bottom of my winshield ive been getts alot of fog down there............Dont really understand it because its been 90-100 degrees here in the DFW.........When I turn on the defroster nothing happens fog just seems to stay there unless I clean the glass
What could be happening bad seal on the windshield???
Old Jul 3, 2011 | 09:04 AM
Beob's Avatar
Possibly an antifreeze leak. You should be able to smell it if its leaking.
Old Jul 3, 2011 | 09:23 AM
Lady72nRob71's Avatar
Is it only near the defrost ducts? If so, suspect leaking heater core or moisture from working AC or water in the AC box cause by rain or washing.
If it is across the whole lower WS, suspect plastic outgassing. That is a common occurance and sice the bottom of the WS is close to the dash, that could be the issue..
Old Jul 3, 2011 | 09:56 AM
Definetley not a coolant leak, ill check some things Rob and get back to you, you might just have something here.
Old Jul 4, 2011 | 04:54 AM
Bunser's Avatar
Originally Posted by lady72nrob71
is it only near the defrost ducts? If so, suspect leaking heater core or moisture from working ac or water in the ac box cause by rain or washing.
If it is across the whole lower ws, suspect plastic outgassing. That is a common occurance and sice the bottom of the ws is close to the dash, that could be the issue..
x2...
Old Jul 4, 2011 | 05:10 AM
This can often be caused by excessive application of Armor-All or similar products to the dash board.
Old Jul 4, 2011 | 09:01 AM
It seems to be across most of the ws......
I have not used any armor all or any product on my dash ill give it a thorough cleaning though.
Old Jul 4, 2011 | 09:04 AM
Can somebody explain plastic outgassing?
Old Jul 4, 2011 | 12:59 PM
Plastics contain chemicals that continue to evaporate (outgas) long after the parts are made. These chemicals condense on the windshield, forming the fog. Same goes for coatings like Armor All. Even if you've never used it, the previous owner may have. That's what happened with my Allante. Never could keep the windshield clean.
Old Jul 4, 2011 | 03:50 PM
I have that problem with my rear window fogging. I recovered the interior with new headliner and pkg tray covered with the same mat'l as the seats. So I use fine steelwool and window cleaner to remove it. Be carefull around painted surfaces with the steelwool.
70vista
Nov 30, 2013 05:16 PM
jjokrm
Feb 16, 2013 05:15 PM
dallasite21
Feb 24, 2012 01:34 PM
fizzy55
Oct 19, 2010 09:05 PM
linear59look
Body work
Mar 19, 2010 08:08 AM
