1972 Cutlass Cowl Tag Decode, Help!
Old Jun 12, 2011 | 05:00 PM
Dant's Avatar
ST 72-33669 Z 00088 BDY
TR 933 A52 B90 26 26 PNT
08E 004784 080156
Hello, I was wondering if you guys could try and help me out with the cowl tag, so I understand that 3 mean's oldsmobile and 36 represents cutlass and 69 is town sedan but i'm stumped on the rest.
Thanks,
Dan
Old Jun 12, 2011 | 06:04 PM
GAOldsman's Avatar
"Car"mudgeon
33669= Cutlass 4 Dr Pillar Sedan
Z= Fremont CA Assembly Plant
00088= Production Unit Number
933= Blue Cloth Bench Seat
A52= Bench Seat
B90= Molding, Side Window Reveal
26= Viking Blue Poly Lower Exterior Color
26= Viking Blue Vinyl Top
08E= August 5th week 1971 Production Date
004784 080156 = Codes pertaining to Fremont plant and build sequence (would be on build sheet as blocks as to data processing #'s)
Old Jun 12, 2011 | 06:17 PM
Dant's Avatar
Wow! Thanks! I'm curious about that vinyl top though, as far as I can tell it never had one. Also, does the 00088 mean that it was the 88th car made that year with the body configuration?
Old Jun 12, 2011 | 06:26 PM
GAOldsman's Avatar
"Car"mudgeon
No prob, it could mean just viking blue upper body color. Does not specify if it is vinyl top but normally it would be. The 00088 means it was the 88th Oldsmobile body built at Fremont for the 1972 model year in 1971.
Old Jun 12, 2011 | 06:28 PM
GAOldsman's Avatar
"Car"mudgeon
Was it an export to Canada?
Old Jun 12, 2011 | 07:22 PM
VikingBlue's Avatar
26 26
Is viking blue paint top and bottom....blue vinyl would be a letter code, maybe C but not sure.
e.g viking blue paint with blue vinyl would be 26 C (or some other letter)
with a convertible VIN and body code, the letter would stand for the top color.
Old Jun 12, 2011 | 07:40 PM
GAOldsman's Avatar
"Car"mudgeon
Yep I see that now and it's not showing a blue vinyl top for '72.
Scot
Old Jun 12, 2011 | 09:53 PM
Dant's Avatar
No, the lady I bought it off of said that her uncle drove it up form California shortly after he purchased it in '72.
Old Oct 19, 2015 | 11:51 AM
donaldl442's Avatar
I was wondering if you could help decode my cowl tag
ST 72 33687 R 23608 BDY
TR 949 A51 56 F PNT
06A0966
Old Oct 19, 2015 | 05:16 PM
1970cs's Avatar
Lansing built
TR 949 A51 56 F PNT
06A0966
You should have started your own post!
ST 72=1972 year
3=Oldsmobile
36=Cutlass V8
87=hardtop coupe
R=Arlington TX Fisher body
23608=build sequence
TR=trim
949 saddle themed interior
A51 ? molding of some sort
56=Sunfire Yellow
F=Saddle tan vinyl roof cover
06A0966?
Old Oct 19, 2015 | 07:17 PM
jaunty75's Avatar
He's possibly running characters together?
The 06A at the beginning of the last line could be the build date, first week of June (1972).
I have A51 = front bucket seats
Old Oct 20, 2015 | 02:49 AM
1970cs's Avatar
Lansing built
Thanks for help out Jaunty!
Pat
Old Oct 20, 2015 | 08:14 PM
GAOldsman's Avatar
"Car"mudgeon
And 0966 is meaningless as far as I know. Arlington, Fremont and Lindon used these #'s as pertaining to the build and were pretty much in-house (Fisher Body) (only) as related to the build/build sequence.
1arunem
May 12, 2020 10:52 AM
Mikel7099
Oct 21, 2013 04:37 PM
Skitch72
Sep 20, 2013 09:39 AM
jmt147
Oct 19, 2012 07:31 PM
neller840
Jul 28, 2010 05:01 PM
