What size trailer ?
Old Jan 22, 2011 | 04:33 PM
fmbjogger's Avatar
What size trailer ?
I want to trailer my '75 Delta 88 Royale to shows come spring. Is a 16' 7000lb dual axle w/brakes appropriate for the job ?
Old Jan 22, 2011 | 06:46 PM
Is the 7000 lbs gross weight? I assume usable payload is around 5000 lbs. That and the length are cutting it close. I have a 10,000 lb, 18 ft trailer, and while weight isn't a problem, length is close with my Custom Cruiser on it.
Old Jan 22, 2011 | 06:51 PM
gearheads78's Avatar
car guy
16' is going to be pushing it on the size. I would recommend 18' at a minimum.
Old Jan 23, 2011 | 12:08 AM
66 Olznut's Avatar
Ca's Only Official OLZNUT
I know my '66 442 is 17' long. The main question is if the deck is 16' or is the length 16'? Some people measure them differently. The car will fit on a 16' deck but the tail will stick off the rear a bit. You will also be pushing it close to the max weight. A typical open car trailer is 2000lbs give or take a few. A 17' Featherlite open trailer weighs in at 1300lbs with a 7000lb gvw but costs $5k new.
<blshakers>
Cars Wanted
Feb 28, 2011 07:02 PM
Nailhead 88
Nov 20, 2008 11:01 AM
Jakespeed63
Jan 14, 2008 07:55 PM
ztim
Sep 17, 2006 01:53 PM
blshakers
May 26, 2003 09:50 PM
