Question regarding Intake manifold
Old January 13th, 2011, 03:57 PM
CaliCutty26's Avatar
So it appears as though i will be rebuilding the 3.8L v6 on my 85 cutlass. I was looking for intake manifolds but i only found a couple (one of them being an intake manifold for the buick v6), is that one compatible with my engine? Are the buick/olds engines the same? Thanks in advance for your help!
CaliCutty26 is offline
Old January 13th, 2011, 04:07 PM
Funkwagon455's Avatar
It's a corporate GM engine that went into all of the g-bodies through the eighties, identical to the Buick application.
Funkwagon455 is offline
Old January 13th, 2011, 04:08 PM
Hangin' out...
henryk8398's Avatar
The 3.8 V6 is a Buick engine made for all GM divisions, so you're rolling in a true Oldsmobuick.
henryk8398 is offline
Old January 13th, 2011, 06:25 PM
any other recommendations for upgrading the v6?? Thanks!
Old January 13th, 2011, 06:57 PM
71 cutlass convertible
lshlsh2's Avatar
Any olds v8. If you don't want to spend much I sure someone has a 307 that they would let go cheap.
Larry
lshlsh2 is online now
Old January 13th, 2011, 07:57 PM
85_Cutlass_Sedan's Avatar
i have been thinking of doing a engine swap down the line in my Cutlass Sedan... i was thinking big block or large small block... i think i will clean up the 3.8L in mine for time being and fix its leaks till i get around to finding an engine to replace what it has... have you thought about getting heads redone, along with them ported along with the intake?
85_Cutlass_Sedan is offline
Old January 13th, 2011, 08:13 PM
Im also thinking about that as well...around how much do you think that will cost me? My budget is $1,200. Im also looking to do upgrades to the transmission. Any suggestions?
Old January 13th, 2011, 08:36 PM
Red71's Avatar
If I remember correctly, the front cover on those 3.8 are part of the oil pump.
So make sure you inspect that area for wear. And
there is/was a good v6 book out there for sale by S.A. Design that covered v6.
Red71 is offline
pherbicide
February 7th, 2015 06:19 AM
boese1978
April 1st, 2013 12:21 PM
VinMichael
April 2nd, 2012 08:17 PM
wjustinmartin
February 18th, 2010 05:45 AM
james455
October 24th, 2009 02:07 PM
Quick Reply: Question regarding Intake manifold
