More, startup advice
Old August 29th, 2010, 01:25 PM
ITS68's Avatar
Didn't want to hijack the thread below. In our case we have several cars and at least two haven't been started since the late 80's. I heard somewhere that you should pull the plugs and squirt a little motor oil into the cylinder. Is that necessary or is the advice below plenty good enough?
ITS68 is offline
Old August 29th, 2010, 01:35 PM
442much's Avatar
I heard that too. And since this car is in the UK (humid conditions) I'd do the same.
442much is offline
Old August 29th, 2010, 03:15 PM
70 cutlass s's Avatar
What are your plans for the cars just to move them or to get running for driving. A car that has been setting for 20+ years. I would be weary checking and replacing a lot of things.
Personally I would pull the engine and rebuild it. If you have any long term plan for the car. If you plan on just selling the car, then sell it as is. I know that if I was buying a car that has been setting that long with plans to restore. It not running wouldn't effect me buying
70 cutlass s is offline
Jaybird
June 6th, 2016 03:51 PM
hookem horns
Brakes/Hydraulic Systems
April 22nd, 2013 07:27 AM
ChefDeadpool
March 2nd, 2012 05:44 PM
boondocker
August 24th, 2011 05:33 AM
case2273
July 15th, 2009 02:00 PM
Quick Reply: More, startup advice
