Removing Power Steering Pulley and Bracket
Old Aug 22, 2010 | 02:52 PM
Steve Wike's Avatar
Wondering if this has been done and what tool do you need? Looks like the tool screws in down about 1" the middle of the shaft hole and then I guess with pressure applied, it pushes up off the shaft itself? Any help would be apprecaited. I am cleaning this and the back bracket. Thanks!
SJW
Old Aug 22, 2010 | 03:19 PM
Maybe, once or twice perhaps...
SJW
The first question is, do you have a pulley with a nut and keyway, or the pressed-on style? The easiest way to loosen the nut is while the pump is still on the car and the belt is tensioned. The pressed on style needs a pulley remover tool.
http://www.amazon.com/PULLEY-REMOVER.../dp/B000F7VCDW
Old Aug 22, 2010 | 04:18 PM
Steve Wike's Avatar
Removing Pulley
Looks like a pressed on one. In the center is a "hex" nut point of entry, and them threads below that, so I guess it's pressed on?
Old Aug 22, 2010 | 06:45 PM
It will be pretty obvious if there's a large nut holding the pulley on the shaft. If not, you have the pressed on version. The hole in the shaft is so you can reinstall the pulley. A bolt is threaded into the hole and a nut and washer used to pull the pulley back onto the shaft.
Olds luvr
May 13, 2016 06:37 PM
Johnd
Sep 1, 2014 10:00 AM
nicks1966
Jan 12, 2014 01:46 PM
WTony
Mar 21, 2013 01:28 PM
xerxes600rr
Aug 30, 2011 06:43 AM
