Removing valve cover baffles
Old April 28th, 2010, 12:43 PM
mgue67's Avatar
I’m installing new Edlebrock heads on my 350. I would like use the old valve covers but the baffles will not clear the rocker studs. If I go with taller valve covers I understand that my accessory brackets will not fit. Can anyone provide experience with removing the baffle or other options?
mgue67 is offline
Old April 28th, 2010, 01:31 PM
Eddie Hansen's Avatar
similar circumstances, I went with a set like the dick miller stock looking covers that are a little higher ( 3/8ths of an inch, but I am NOT running a/c this is the bracket your worried about right? I was told these would fit a/c, but I was also told santa is a jolly old elf.... I didn't get the dick miller ones i got them from some place in Kali-forni-A about half the price look the same..
the baffles are just spot welded in and "should" come out fairly easy, but you know how that goes LOL...
wish I could be more help
Eddie Hansen is offline
Old April 28th, 2010, 01:35 PM
Blk71SX's Avatar
if you remove the baffle associated with the pcv valve it will probably start sucking oil.
been there
Blk71SX is offline
Old April 28th, 2010, 07:44 PM
O's_Car's Avatar
My engine builder removed the baffles in my valve covers to clear the rockers. He saved the portions that cover the PCV holes in each valve cover and welded them back in. They line up between rockers and should keep oil from easily sucking through the PCV system. He left some air gaps around the trimmed baffles to allow ventilation.
O's_Car is offline
Old April 28th, 2010, 10:27 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
Get a hold of some 64-66 330 or 425 valve covers. They don't have baffles in them.
J-(Chicago) is offline
tgilligan
June 22nd, 2014 01:57 PM
Pacecar
August 8th, 2012 04:40 AM
tim72
June 30th, 2010 04:41 PM
VikingBlue
June 4th, 2010 03:07 AM
tim72
May 22nd, 2010 08:11 PM
Quick Reply: Removing valve cover baffles
