Baffles Valve covers
Old Jun 30, 2010 | 07:00 AM
tim72's Avatar
My roller rockers are hitting my baffles inside my edelbrock valve covers. I have cut the baffles out but......... my problem is the airconditioning braket will not except a taller valve cover. Anybody figure a way of modifying or finding a different valve cover that will work with the baffles?
Old Jun 30, 2010 | 07:52 AM
Eddie Hansen's Avatar
how much room?
Tim how much room do you have? I do not have a/c, but I went with a stock type chrome cover that is only 3/8ths of an inch higher, I am running harlan sharps and they do not hit... but from what I remember the a/c bracket is like right there!! maybe not even that much room, can you use a spacer on the bracket and perhaps modify it a bit to get the clearance?
Old Jun 30, 2010 | 04:41 PM
tim72's Avatar
Eddie got it figured out. Basically had to cut a hole in the baffle. We then adjusted the baffle ( hammer) to clear. So if there is a will there is a way. Eddelbrock valve covers have there holes in the back on the passenger side and any breather hits the air con housing. Stock valve covers have the breather hole in the middle. Also the performer intake hole that locates the air con bracket is not exactly in the right spot. so had to do some major filing to get the stud to hit the threaded hole. also ther braket attaches to the head bolt so the holes have to be a perfect fit. No chance of shiming the bracket. Can you tell me what valve covers you did get for your car? did they have baffles in them?
Thanks for your thoughts on how to come to some solution.
RAMBOW
Mar 20, 2017 06:58 PM
jpc647
Oct 12, 2012 03:11 PM
Ric
Oct 23, 2011 05:32 PM
tim72
May 22, 2010 08:11 PM
mgue67
Apr 28, 2010 10:27 PM
