Clocks
Old Apr 13, 2010 | 05:46 PM
ODan's Avatar
67s98sConv4dr
Clocks
{ Someone was asking about clocks } (Electric clocks) Regulation of electric clocks used on automobiles is accomplished automatically by merely resetting the time. If the clock is running fast, the action of turning the hands back to correct the time will automatically cause the clock to run slightly slower. If the clock is running slow, the action of turning the hands foward to correct the time will automatically cause the clock to run slightly faster (10 to 15 seconds a day). (Winding Clock When Connecting Battery Or Clock Wireing). The clock requires special attention when reconnecting a battery that has been disconnected for any reason, a clock that has been disconnected, or when replacing a blown clock fuse. It is very important that the initial wind be fully made. The procedure is as follows: 1. Make sure that all other instruments and lights are turned off. 2. Connect positive cable to battery. 3. Before connecting the negative cable, press the terminal to its post on the battery. Immediately afterward strike the terminal against the battery post to see if there is a spark, If there is a spark, allow clock to run down untl it stops ticking, and repeat as above until there is no spark. Then immediately make the permanent connection before the clock can again run down. The clock will run down in approximately two minutes. 4. Reset clock after all connections have been made. The foregoing procedure should also be followed when reconnecting the clock after it has been disconnected, or if it has stopped because of a blown fuse. Be sure to disconnect battery before installing a new fuse.
Troubleshooting: If Clock does not run, check for blown (clock) fuse. If fuse is blown check for short in wiring. If fuse is not blown check for open circuit. With an electric clock, the most frequent cause of clock fuse blowing is low voltage at the clock which will prevent a complete wind and allow clock contacts to remain closed. This may be caused by any of the following; discharged battery, corrosion on contact surface of battery terminals,lose connections at battery terminals, at junction block, at fuse clips, or at terminal connection of clock. Therefore, If in reconnecting battery or clock it is noted that the clock is not ticking, always check for blown fuse, or examine the circuits at the points indicated above to determine and correct the cause.
Old Apr 13, 2010 | 05:49 PM
MJAKS462's Avatar
Wow , great post ! Wish I had a clock to work on.
Old Apr 13, 2010 | 05:56 PM
jensenracing77's Avatar
this is funny to see this post. i was just outside working on a clock out of the 70 convertible i just got. anyone know where to get fresh hands for the clock. i got it working but the hands are faded.
Old Apr 13, 2010 | 06:16 PM
MJAKS462's Avatar
yea it is weird how many times I have been working on something and come in and get on line and someone has a great answer waiting for a question that I was about to ask.
jensenracing77
Aug 13, 2011 09:06 AM
hialeah56
Aug 12, 2011 04:29 PM
ros6872
Jul 28, 2011 09:45 AM
Hairy Olds
May 8, 2010 10:04 AM
Hairy Olds
Aug 5, 2009 08:53 PM
