1966 Cutlass Radiator Support - Difference in a/c and non a/c?
Old May 29, 2025 | 09:16 AM
boogerboo's Avatar
I heard there was a difference in air condition and non air condition radiator core supports for a 1966 Cutlass. I haven't found a difference yet. What is the difference?
Old May 29, 2025 | 09:48 AM
zl1 camaro's Avatar
Just a guess > I would think the a/c radiator core support maybe a little wider, also don't forget the condenser sits in front of the radiator as well. I guess the question is did GM use the same for a/c vs non a/c cars. I can measure my 66 442 NON A/C and get back to you if you have a cutlass with a/c you can compare. Someone on this site may know this, this is a good question...
Old May 30, 2025 | 07:20 AM
newmexguy's Avatar
These parts are from a '66 AC car. I frankly don't know the difference between, or if there is a difference.
Old May 30, 2025 | 08:35 AM
The difference would depend on the radiator. AC cars got heavy duty cooling, which contained V01 bigger radiator. I don't know if the cradles were different on it, probably 2 vs 3 core tanks. The condenser bolts onto the actual core support, not the radiator top and bottom plates shown here.
Old May 30, 2025 | 08:57 AM
66-3X2 442's Avatar
There isn't any difference in any 66 radiator support. The A/C cars have additional bolt in brackets for the condenser and the upper and lower plates are the same except the 6 cylinder cars. 2 row and 3 row radiators have the same tanks, so the saddles are the same.
Old May 30, 2025 | 01:19 PM
Run to Rund's Avatar
To expand on the above response, the upper and lower plates are the same on 6 cylinder and v8 cars, except for where the saddles are welded to them.
lknighton
Jun 18, 2021 08:45 PM
lknighton
Jun 18, 2021 05:54 PM
forstatd
Oct 11, 2020 12:55 PM
RandyS
Mar 28, 2018 05:03 PM
RandyS
Oct 22, 2017 10:12 AM
