1966 Oldsmobile Weatherstripping
Old Nov 25, 2024 | 01:02 PM
Jason Ludtke's Avatar
Hello all,
I have a 1966 Oldsmobile Delta 88 Holiday Sedan and the weatherstripping around the doors and windows are original, cracked, deteriorated, etc.
We had our first snowfall and water is started to seep in and soak into the door panels. Are there any alternatives to preventing water from seeping in other than replacing the weatherstripping?
I called Classic Industries and Original Parts Group and neither of them have weatherstripping for the Olds I have.
Any ideas?
Thanks!
Old Nov 25, 2024 | 02:18 PM
OLDSter Ralph's Avatar
Originally Posted by Jason Ludtke
Hello all,
Any ideas?
Thanks!
A car cover or tarp is your solution til you get new weather stripping installed.
Old Nov 25, 2024 | 02:46 PM
Tri-Carb's Avatar
Try https://www.steelerubber.com/?srslti...IQwBVBMRBtzVC8
Old Nov 25, 2024 | 03:10 PM
Did some researching and I came to the same conclusion, thank you!
Old Nov 25, 2024 | 03:11 PM
Originally Posted by Tri-Carb
I’ll make sure to give them a call, thank you!
Old Nov 25, 2024 | 03:28 PM
Tri-Carb's Avatar
You can type in your auto info to verify they make it. I did a quick check and SR seems to make it. SR is the most comprehensive maker of weatherstripping. Original Parts Group is a re-seller. The big 3 manufacturers are Soft Seal, Metro and Steele Rubber.
Old Nov 25, 2024 | 03:55 PM
Thank you so much for your input, I really appreciate it!
Old Nov 26, 2024 | 07:12 AM
jaunty75's Avatar
You don't need to call them. Just go to their website and order it.
From the Steele website.
Old Nov 26, 2024 | 07:18 AM
jaunty75's Avatar
Metro Molded Parts has lots of stuff, too.
https://metrommp.com/catalogue/?Year...del=Delta%2088
As does Rubber the Right Way.
https://www.rubbertherightway.com/c-...-products.html
Of course, don't forget Fusick, but Fusick just resells rubber made by other companies.
https://www.fusickautomotiveproducts...s.asp?dept=729
cfair
Sep 22, 2023 04:01 PM
alfalucy99
Oct 6, 2021 04:00 PM
kingtut
Mar 28, 2013 06:56 PM
66olds4dr
Jun 11, 2011 08:49 AM
clay
Mar 9, 2009 11:29 AM
