1966 Oldsmobile Weatherstripping
Hello all,
I have a 1966 Oldsmobile Delta 88 Holiday Sedan and the weatherstripping around the doors and windows are original, cracked, deteriorated, etc.
We had our first snowfall and water is started to seep in and soak into the door panels. Are there any alternatives to preventing water from seeping in other than replacing the weatherstripping?
I called Classic Industries and Original Parts Group and neither of them have weatherstripping for the Olds I have.
Any ideas?
Thanks!
Any ideas?
Thanks!
Hello all,
Any ideas?
Thanks!
Any ideas?
Thanks!
You can type in your auto info to verify they make it. I did a quick check and SR seems to make it. SR is the most comprehensive maker of weatherstripping. Original Parts Group is a re-seller. The big 3 manufacturers are Soft Seal, Metro and Steele Rubber.
Thank you so much for your input, I really appreciate it!
Metro Molded Parts has lots of stuff, too.
https://metrommp.com/catalogue/?Year...del=Delta%2088
As does Rubber the Right Way.
https://www.rubbertherightway.com/c-...-products.html
Of course, don't forget Fusick, but Fusick just resells rubber made by other companies.
https://www.fusickautomotiveproducts...s.asp?dept=729
