It's a reasonable assumption that the 39-48 16" rims may not fit your 1937 model, despite both being 16". While they share the same diameter, factors like rim width, offset, and bolt pattern can differ significantly between those years. It’s best to check compatibility specifications or consult with a vintage parts expert to ensure a proper fit. As a working student, balancing a job and school assignments can be tough. I needed help with my coursework, and that’s when I came across
academized.com/write-my-coursework They delivered a well-researched, thoroughly edited piece of coursework that not only met my expectations but exceeded them. I was able to submit it on time and still had time to focus on my job. I will definitely be using this service again in the future for other assignments.
