69 442 Dash speaker
Old Jul 28, 2024 | 02:46 PM
SIXPS's Avatar
69 442 Dash speaker
Does anyone make a direct bolt in dash speaker for a 69 a body?
Old Jul 28, 2024 | 03:23 PM
dc2x4drvr's Avatar
Check with this outfit, I’m pretty sure they have a direct fit speaker for a ‘69, quality products.
Electro-Tech, couldn’t paste the url for some reason..
Old Jul 30, 2024 | 03:44 AM
Noel Anderson's Avatar
I used these people, even had them upgrade my radio.
http://www.turnswitch.com/speakers.htm
Noel
Old Aug 7, 2024 | 03:47 PM
NP 70 442's Avatar
Just went through this as part of a project on my ‘68 to fix some dashboard electrical mods by the PO. If going with a stock Delco radio, you want to grab a new “Special Rectangle” speaker from Electro-Tech (turnswitch is their web URL). This will get you the correct shape to fit the dash as well as the 10 ohm impedance speaker you need for the original radio. Dummy me forgot about this when I installed an original AM-FM setup and hooked it up to the modern speakers installed into my original frame (see photo) blowing the output circuit of my radio. Had to replace the output transistor (large can one in the heat sink of the radio) after scoring a couple off eBay. Make sure you have the Oldsmobile specific speaker mounting bracket to put the new speaker in the dash. Be prepared to use some profanity and for some scrapped hands to work with the absolute PITA ‘68-9 dash design, especially if you have an AC car. The new owner of Electro-Tech is super helpful with advice and info on their products.
Note the speaker shape and seller info. Great quality USA made product.
Modern speakers installed into the old original speaker housing.
Good luck, hope this helps. PM me if you have any additional questions I might help with.
Old Aug 12, 2024 | 03:36 AM
EmilySullivan's Avatar
Spoiler
Thanks for answering, I appreciate you for taking the time to write it.
Arrowstorm
Oct 22, 2023 09:10 AM
BSiegPaint
May 20, 2021 11:42 AM
jankyrre
May 27, 2014 11:54 PM
Winger67
Jun 19, 2013 06:55 PM
oldsonharmont
Apr 30, 2010 03:04 AM
