1964/65 N93 Wheel option help
Old Nov 16, 2023 | 07:46 AM
oldsrocket88's Avatar
Looking for substitute options for the 3 studs that hold on the wheel cover of the N93 steel wheel options.
I've read a carriage bolt works if not looking for a 100 point correct numbers matching solution, Any advice or options? Are there modern day replacement bolts that will do the job? Elevator bolts? OEM replacements out there? ( I know that's like asking for Hen's teeth).
They simply hold on the cover, so I can't think that a solution cant be found.
Thanks i advance for any help/ideas.
Old Dec 6, 2023 | 10:31 AM
No alternative ideas out there?
Old Dec 6, 2023 | 05:58 PM
Oldsmaniac's Avatar
I was missing a few of the original ones and I fabricated my own just like originals. It was hard to find correct threaded lug nuts so I brazed up the holes and re tapped... This shouldnt be hard with someone with proper tools.
4-Speed
Sep 3, 2020 02:58 AM
MichiDan
Wheels and Tires
May 25, 2017 06:34 PM
jmills
Aug 18, 2015 06:54 PM
Robert Kiedrowski
Nov 22, 2012 11:58 AM
67442nut
Sep 6, 2012 12:17 PM
