front drum to disk brakes
Old Nov 8, 2023 | 05:32 PM
servexcell's Avatar
When doing a conversion for front drum to disk is it required to replace steering knuckles
thanks
Old Nov 8, 2023 | 05:38 PM
If you are doing it correctly, with factory parts, you use factory disc spindles.
Old Nov 8, 2023 | 06:10 PM
servexcell's Avatar
long story i had purchased all the factory parts to convert to disk drakes. I recently disassembled all components of the frame to have everything resanded and repainted.
i am in the midst of reassembling everything on the frame and was only asking because i noticed that the steering knuckle if turned to much can touch the lower control arm.
thanks
Old Nov 8, 2023 | 07:22 PM
thanks
That will happen until you assemble the entire suspension and steering and have the car at ride height. Don't make a problem that where one doesn't exist
Old Nov 9, 2023 | 02:45 PM
servexcell's Avatar
thank you kindly for your expertise
Old Nov 17, 2023 | 03:06 AM
GaynSchiller's Avatar
Any update?
Spoiler
griffey57
Oct 19, 2020 06:07 AM
SteveRob442
Brakes/Hydraulic Systems
Jul 10, 2017 09:20 AM
griffey57
Oct 9, 2016 03:47 PM
cheven
Feb 16, 2012 08:44 AM
Doug in SD
Suspension & Handling
Jun 8, 2011 05:59 AM
