67 W30 horn quiz
Old Oct 8, 2023 | 08:04 AM
aqua67w30's Avatar
67 W30 horn quiz
My fully documented original sheet metal 67 W30 has no holes in the fenders to mount the horns. I removed the horns in '79 the first time I had the car stripped and painted. I never reinstalled them and don't remember where they were mounted. I've lost them somewhere over the years. My car has a 3/15/67 dealer delivery date. Is it possibly an early car and they changed horn location after? Has anyone seen another example like mine?
Old Oct 9, 2023 | 10:27 AM
67OAI's Avatar
Old(s)GuysRule
What is the build date as noted on the body tag? My W30 is an early build, 01C (3rd week of January), and has the horn relocation as noted in the PIM. Do you have a complete copy of the PIM? If not, you should contact Hairy Olds on this site. You shall also need the template which Hairy may also have or he may be able to direct you to someone who does. Attached is a copy of the page from the PIM which shows where the horns get relocated. Good luck!
File Type: pdf
Old Oct 9, 2023 | 10:31 AM
66-3X2 442's Avatar
Your car is one of the 4 built in January. What rear axle gear does it have?
Old Oct 9, 2023 | 10:59 AM
Hairy Olds's Avatar
Shoveling Snow
Old Oct 10, 2023 | 06:37 AM
67OAI's Avatar
Old(s)GuysRule
66-3X2 442, 3.55 gear originally, 4.66 currently. PM sent.
Old Oct 13, 2023 | 06:43 AM
aqua67w30's Avatar
67OAI, I don't want to relocate my horns to the fenders, I'm asking if any other 67 W30 came without the horns relocated to the fenders. I'm sure mine isn't the only one.
Old Oct 13, 2023 | 08:13 AM
67OAI's Avatar
Old(s)GuysRule
Are you the original owner of the car? If not isn't it possible that there may have been collision damage at some time prior to your ownership and the front fenders replaced at that time?
Old Oct 13, 2023 | 02:05 PM
aqua67w30's Avatar
I'm not the first owner. I personally know the dealer who ordered it, who gave me the dealer invoice slip. I know the first owner and the second owner, met the third owner. My brother bought the car in '73 and I've owned it since '77. I had the car stripped and repainted in '79 because the original paint was flaking, a common GM problem with light metallic paint during this time period. My car has all original sheet metal. It has never been wrecked.
italian ice
May 8, 2019 06:25 PM
steverw
May 14, 2017 07:49 PM
Octania
Mar 20, 2015 10:34 AM
Crow442
Feb 18, 2014 04:41 PM
rancher753
Jan 16, 2014 08:30 PM
