I dropped my 9/16 socket
Old Mar 3, 2023 | 10:04 AM
Here it is in the oil pan of the 455 in my 71 98.
Old Mar 3, 2023 | 10:40 AM
Ack! I'm guessing that went in through the distributor hole?
Old Mar 3, 2023 | 10:46 AM
Sugar Bear's Avatar
A well guided magnet or pickup claw and a lotta luck!
Old Mar 3, 2023 | 11:00 AM
Yes, it fell into the distributor hole. I was planning to leave it there, but on second thought...
Old Mar 3, 2023 | 11:45 AM
fleming442's Avatar
Put a neodymium magnet under it.
Old Mar 3, 2023 | 11:55 AM
I'm surprised. I though that only happened with 10mm sockets,
Old Mar 3, 2023 | 12:10 PM
Good idea. We'll see if I go with that. 🤔
Maybe on my 86 F250 or my 96 98, but I don't think there's a single metric fastener on our classic Oldsmobiles. 😁
Old Mar 3, 2023 | 02:28 PM
Just leave it, it's not going anywhere and there is 0 chance for it to do any damage.
Old Mar 3, 2023 | 02:31 PM
Agreed, though the thought of a magnetic drain plug also came to my mind.
Old Mar 3, 2023 | 03:07 PM
Thanks for the comments and advice. I'll keep everyone updated.
Old Mar 3, 2023 | 03:46 PM
I'm thinking it will never bother a thing, as long as we continue to have gravity and you keep car on its tires! Yeah it would be nice to get it out. I dropped a bolt down into a 5.4 Ford right up front where the timing chain is. I just rolled engine over by hand, making sure no noises, etc. Then ran truck until I sold it much later.
Old Mar 3, 2023 | 04:01 PM
Sugar Bear's Avatar
Had a timing chain break on a V-6 Chevy (229 CID) in an Impala in the eighties. Customer made a panic stop, an extra from the factory rocker arm nut rolled forward and was jammed onto one of the gears which snapped the chain. It was the only time I've seen a GM chain snap. Lot of bad stars must have aligned that day.
I agree it will very likely be fine if you can't get it out, The addition of an external magnet is a good idea.
Good luck!!!
Old Mar 3, 2023 | 04:41 PM
fleming442's Avatar
Unless, of course, the engine could come out anyway for fresh gaskets and paint..... Giddy up! 🤣
Old Mar 3, 2023 | 05:00 PM
Any other sockets you don't need? Toss them in there, as well...misery loves company.
Old Mar 3, 2023 | 06:58 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Unlike the plastic timing gear spockets, this will not get sucked up into the oil pump screen,
Old Mar 4, 2023 | 05:19 PM
I pulled apart a small block Chevy that had 2 extra rod nuts I.m in the oil pan. The wagon it came out of had 150K miles on it and didn’t appear to have ever had major work done. I’m betting they had been there since day one. Looks like whoever torqued rod nuts on the assembly line was either new, or had way too much to drink the night before.
Old Mar 5, 2023 | 05:06 AM
Oldsguy's Avatar
Past Administrator
Jesse, the guy with the red beard will know!
Last edited by Oldsguy; Mar 6, 2023 at 07:48 PM. Reason: corrrected spelling error
Old Mar 5, 2023 | 05:28 AM
BlueCalais79's Avatar
When I was removing my distributor, I had the rod that connects from the bottom of the distributor to the oil pump fall off on me and it went right down to the bottom of the oil pan. I used one of those retractable magnets, the one that looks like a pen when its retracted and a car antenna when it is outstretched. It took some doing getting it past the intake manifold as it wanted to stick there, and then more effort once it was submerged.
It took try after try for about an hour and I was about to give up when I felt and heard that un-mistakeable CLICK and I knew I had it. Not unlike landing that big bass you've been after all season!
And another thing, why does this stuff always happen only when it's about 15 degrees out!
Old Mar 6, 2023 | 05:41 AM
I bought a magnetic oil pan drain plug.
https://votex-us.com/
I already test fit it to make sure it would work, but I haven't installed it and added oil yet.
Old Nov 21, 2025 | 05:45 AM
Two & 1/2 yrs later...and?
Old Nov 21, 2025 | 06:46 AM
It's probably still there....
Old Nov 21, 2025 | 06:48 AM
Yep, I thought about it this morning when I posted the link to this thread. I guess that is an extra reason to keep my hands on this car. I need to get that socket for my collection of treasures.
72455442RA
Mar 22, 2022 09:09 AM
Jan 11, 2022 04:36 PM
johnwrolds2018
808olds
Sep 16, 2010 08:13 PM
captn442
Jun 22, 2009 07:42 PM
