455 Torque Strap
Old Sep 10, 2022 | 01:23 AM
pettrix's Avatar
455 Torque Strap
Well, after 20 years, the drivers side torque strap cable is starting to break some strands. Where can one purchase such a cable today?
Old Sep 10, 2022 | 02:17 AM
fleming442's Avatar
I used to have a piece of chain on the front of the head to a steering box bolt.
That one looks to be on a head bolt? How do you maintain the torque? Not a fan....
Old Sep 10, 2022 | 03:21 AM
pettrix's Avatar
I have head studs and I've never had any issues with the strap connection. Nut never loosens. Only issue after 20 years is some of the strands broke on the cable. Still holding but would like to replace it in the future
Old Sep 10, 2022 | 04:55 AM
fleming442's Avatar
Didn't Mondildo sell those? You could duplicate it with $10 worth of parts from the hardware store.
As far as the attachment point, if it works, that's fine, but I wouldn't do it that way.
Old Sep 10, 2022 | 07:33 AM
Run to Rund's Avatar
Your local crane and rigging supply can make up a cable to the length you want.
Old Sep 10, 2022 | 09:22 AM
x2
Old Sep 10, 2022 | 10:36 AM
therobski's Avatar
Some of the Buick Grand National guys fabbed them using an old seat belt-just an idea.
Old Sep 10, 2022 | 12:46 PM
ELY442's Avatar
Mondello sells a flat bar with some kind of a bend. I bought one but never had it installed. I had a friend weld a chain onto a frame and bolt the other end by the headers.
Old Sep 10, 2022 | 12:48 PM
ELY442's Avatar
X2 with a chain but one end of the chain was welded onto the frame and the other end was bolted to the headers.
Old Sep 10, 2022 | 07:14 PM
That could be done with a 1/8 aircraft cable and 4 copper crimps.
Old Sep 11, 2022 | 11:52 PM
Before I installed solid engine mounts I had a threaded turnbuckle and some 3/16 steel strap, one piece on the drivers cylinder head, the other wrapped around the frame on one of the steering gearbox bolts. It works well.
Old Sep 14, 2022 | 09:28 PM
Funkwagon455's Avatar
[QUOTE=fleming442;1452128]Didn't Mondildo sell those? You could duplicate it with $10 worth of parts from the hardware store.
Mondello did sell these in the late nineties, I had bought one myself. I ended up using the head stud but opted to use chain to attach. If you like the cable, I’d opt to fabricate as others have suggested via Home Depot run.
Old Sep 25, 2022 | 01:42 PM
ELY442's Avatar
I was cleaning my tools and found this in the back shelf that I bought from Mondello a long time ago. It’s a torque strap that connects one end to the upper control arm to the cylinder head bolt
Old Sep 27, 2022 | 11:05 AM
chuck_royle's Avatar
I got this from slummit and made a simple bracket with three holes
redbaron442455
Aug 10, 2020 04:12 AM
jpayne_80@hotmail.com
Aug 29, 2019 08:03 AM
Al Sanchez
Feb 26, 2014 03:10 PM
Charles Ludwick
28
Mar 7, 2012 04:45 PM
mhood
Aug 19, 2010 02:38 PM
