1966 442 brake pedal return spring
Old Aug 8, 2022 | 11:12 AM
JRSL69's Avatar
J.R.
I am changing my manual drum single master cylinder over to a dual MC via a kit from inline tube. My car never had a brake pedal return spring and the shop manual also talks about a stop screw to adjust pedal return height. There is no stop screw or any place where one might have been. Do I just use the push rod to adjust the pedal height and can someone post the return spring size and where I can get one?
Thanks Jim
Old Aug 8, 2022 | 01:16 PM
Oldsmaniac's Avatar
They don't use a return spring and yes the pushrod can be adjusted.
Old Aug 8, 2022 | 01:27 PM
Like stated above, there is no brake pedal return spring. The pedal height is adjusted with the clevis/rod from the back of the master cylinder.
Old Aug 8, 2022 | 01:42 PM
JRSL69's Avatar
J.R.
Thanks Guys
Old Aug 8, 2022 | 02:41 PM
66-3X2 442's Avatar
There is absolutely a brake pedal return spring used in 66. I refer all to the 66 PIM/assembley manual section 5 page 2.4. The spring connects to the pedal pin retaining clip and the pedal support. The part # for the spring is 1374386. The pedal heigth is adjusted by the brake pedal clevis. There is no adjustment on the clutch pedal because the pedal rest on the rubber bumper mounted in the pedal support. There has to be a return spring so the pedal will push the brake switch in far enough to activate the switch. I just remembered that the factory used a ball of dum dum where the return spring connects to the pedal support to make sure it stays in place. I've only parted about a 100 or so 66's and remembered the return spring. I'm glad it was in the PIM because ya'll would called me a liar.
Old Aug 8, 2022 | 02:57 PM
RandyS's Avatar
Both of my 66's have brake return springs. I bought them from '4speedconversions'. I just checked and they still sell them, but show out of stock.
Old Aug 8, 2022 | 03:21 PM
I'm not going to doubt, just never saw one on an A body. Sorry for misleading the OP.
Old Aug 9, 2022 | 11:11 AM
JRSL69's Avatar
J.R.
Good to know, I had seen the spring in my assembly manual and there are some remnants of dum dum stuck to the top of the mounting bracket where a spring could attach. I'll just have to find a spring that will work in this application. As RandyS stated, there are some good pictures on 4speedconversions.
Old Aug 9, 2022 | 11:16 AM
Oldsmaniac's Avatar
Yes good to know, my experience is 1964 A body, 1966 full size and 67 A body...dont remember a return spring at all on these... But memories can get foggy
cjsdad
Brakes/Hydraulic Systems
Dec 11, 2023 10:13 AM
long64
Jun 6, 2023 12:49 PM
75royal88
Jul 29, 2019 08:59 AM
Mark71
23
Jul 25, 2016 12:45 PM
Mark71
May 24, 2011 07:11 PM
