68' 442 package tray.
Old Sep 24, 2009 | 06:26 AM
dan1s's Avatar
How do you remove the rear package tray from a 68' 442? Mine is in great shape and I don't want to wreck it.
Thanks, Dan
Old Sep 24, 2009 | 08:55 AM
68Tom's Avatar
Dan--
It's not too difficult, you just have to be careful.
First, remove the back seat. The package tray will be adhered to the metal behind the seat back (i believe)
Then, you need to remove the corner trim pieces that are in each corner nearest the rear window.
At this point, you should be able to remove it. I found that the insulation/jute beneath mine was like dust--makes an awful mess. Just be careful when lifting it.
Your sail panels edges/ends will most likely be tucked under the tray, so they shouldn't get in the way.
Old Sep 24, 2009 | 09:38 AM
dan1s's Avatar
Thanks Tom.
I will give it a shot tonight. I have the back seat and the side panels out already.
It's really adhered to the metal behind the seat back. I guess I will just have to be very careful.
How's the car coming out?
Old Sep 24, 2009 | 10:05 AM
68Tom's Avatar
Well, it's almost done, but still proving to be difficult. The lastest issue is getting the pulleys and a/c compressor to line up and the lack of a antenna retaining nut.
Getting there though....
Old Sep 24, 2009 | 06:51 PM
Cameo White's Avatar
Smile
Doesn't Fusick repop the antenna nut?
cmyolds442
Dec 5, 2013 05:58 PM
getawaycar
Dec 27, 2011 01:41 PM
507OLDS
Aug 23, 2011 06:08 AM
hurst68olds
Feb 4, 2011 07:40 AM
67Olds442X2
May 15, 2010 09:02 PM
