Brake line advice?
Brake line advice?
I'm about to order my brake lines from Right Stuff.
I'll be running non-power disc up front, drum rear.
However, I don't want their proportioning valve hanging off of the MC...and I don't want it INSIDE the frame.
Any tips on keeping it low and out of the way without header interference?
(65 f-85)
THANKS!
(65 f-85)
THANKS!
Unfortunately I doubt you'll be able to get a pre-bent line with the combo valve in a non-stock (or not offered by the aftermarket company) location. The variables in line bending are infinite. Invest in a good set of bending and flaring tools and don't look back.
Flemming...what kit or lines did you use to get the prop valve on top of the frame?
Joe...I'm thinking to get the stock disc brake conversion kit(which puts the proportioning valve up by the MC)
and modifying the last 2 feet. So yeah...I need a nice bender and flaring set.
The 1971-up cars used a combo valve that incorporated the distribution block, differential pressure switch, metering valve, and proportioning valve all in one common housing.
A couple of takeaways from this information.
First, in every case, the factory REDUCED braking force from the rear wheels with disc brakes - both the smaller wheel cylinders on the 67-70 cars and the proportioning function in the combo valve in the later cars limits the force applied at the rear drum brake shoes and thus limits the braking available from the rear wheels. While I realize you are not planning rear discs for this car, one has to wonder at the wisdom of people spending all the money on a rear disc conversion then using the prop valve to limit their performance to the same braking the original drums provided.
Second, the factory tailored the front/rear brake bias for each model, body style, and application. There were a plethora of differently calibrated combo valves listed in the parts book. Today every aftermarket kit uses the same one-size-fits-none Chinesium brass combo valve and you have no idea what it's calibrated for.
Third, the optimum front/back brake bias depends not only on car weight and weight distribution, it also depends on tire size and compound. Unless you have the original tires for the application, your front/back bias requirements will be different from whatever valve you install is designed for. An adjustable prop valve is a far better choice for any modified car, but that requires you to know how to properly set the front/back bias through testing.
Where all this is going is that you're likely better off with an aftermarket adjustable valve, locate it where you want, and bend the lines yourself. Just a thought.
For what you're doing, it might be better to just get the front and rears prebent, then make your own front to rear and master lines.
Yes, that IS a great write up. Lots to think about and soak in.
Joe, my apologies...I simply meant that it is THEIR(Right stuff's) "stock" kit.
But thank you for all the tech info!
Maverick
Brakes/Hydraulic Systems
Jun 26, 2013 08:21 AM
